air problem
Old 08-03-2005 | 08:48 PM
Default air problem
bbc 330hp baja when I have it to the wood I lift the hatch and I will get 3 mph out of it.Does eney body have an idea?
raymo1979 is offline
Old 08-03-2005 | 11:00 PM
hillbilly24's Avatar
Default Re: air problem
Two things, one I wouldn't recomend opening the hatch at any speed that's a real quick way to be hatchless(wich would solve you problem) number two the problem is that the engine cant breathe. never seen the problem with such a mild engine. check and make sure the vents aren't restricted and if need be you can figure out a way to enlarge them or add scoops.
hillbilly24 is offline
Old 08-03-2005 | 11:11 PM
Pwrbt33's Avatar
Talking Re: air problem
Yeah, what he said!!! Also take a look at the bilge vents in the side, I have seen some boat builders put them in wrong.. both facing aft. One should be forward and one back. Or more if you have them.
Pwrbt33 is offline
Old 08-04-2005 | 06:45 AM
The vents are not restricted and they are facing the right way.Will it be safe to put another set of vents on the side or go with the scoop on the hatch.
Thanks,Ray
Old 08-04-2005 | 07:48 AM
From: A tree somewhere in the woods in Clarcona Fl.
A friend of mine had that problem with a 39 Velocity with some stout motors in it,,,,they actually cut a hole in the engine hatch, put a piano hinge system with electric opener on it and the reupholstered it...it was good for app 150 rpms. with the pop-up open..and Velocity already has those naca ducts running up the sides of the deck.
Slick02 is offline
Old 08-04-2005 | 08:41 AM
ratman's Avatar
maybe its the added weight aft when you go back to open the hatch...more bow rise if your portly and move yer azz aft
ratman is offline
mcraymond3
2
05-05-2008 08:00 PM
cbeastwood
4
01-01-2007 08:27 PM
Dock Holiday
20
07-07-2006 09:32 AM
derekdeben
09-24-2004 09:18 PM
skatermike24
04-25-2003 11:29 AM
