OK, what was the reason for this old Edelbrock stuff? >
Old 08-09-2005 | 11:00 AM
pachangalpina's Avatar
Default Re: OK, what was the reason for this old Edelbrock stuff?
Also look at the exhaust logs....never seen a BBC with a pattern like that. Should have equally spaced ports.
This are definatelly unique and possibly rare components but they are not BBC.
pachangalpina is offline
Old 08-09-2005 | 11:04 AM
Originally Posted by Lee
The valve covers and spacers are for a big block Chevy
The intake manifold if for a big block Mopar
The exhaust manifolds are for a small block Chevy
I did not even look at the VC's .....but I agree.
Anyone else having trouble with the site being slow today?
Old 08-09-2005 | 06:14 PM
Payton's Avatar
Charter Member #927
WOW you guys are good! Looks like a couple of guys might be intrested in those rare parts.
Arcticfriends, is that you bidding? Good luck
Payton is offline
Old 08-09-2005 | 06:18 PM
articfriends's Avatar
yep
articfriends is offline
Old 08-09-2005 | 06:32 PM
rmbuilder's Avatar
MarineKinetics
Originally Posted by articfriends
yep
Watch out, Smitty's getting new engine parts! The scarey part is he'll make them work!
rmbuilder is offline
Old 08-09-2005 | 07:08 PM
Hang Time 27's Avatar
I wonder what the single round tubes were for going towards middle,theres where my guess for turbo setup came,maybe they connect and its a balance tube,Smitty
The single round tubes in the center connect together to join the two plenums for better intake tuning -- that was one of the problems with the chevy cross ram that had no connection between the two...........
Hang Time 27 is offline
Old 08-10-2005 | 04:29 AM
Come on Bob! By now I expected pictures of those two piece intake manifolds for the small block Chevy with the two four-barrel set-up! Can't go down memory lane without them! Lou
Lmarth is offline
Old 08-11-2005 | 10:42 PM
That's a cross ram setup for a big block chrysler, 62-64 vintage.
I had that setup on my 64 big block Sport Fury. Very nice. Gobs of torque.
The crossover tube is to equalize the manifolds. If you look at the second picture, under the carb mounting flange, you can see the small flange where the exhaust manifold heater tube connects to heat the choke well.
This setup used low cast iron exhaust manifolds that the carb sat directly over. You had to take the intake off to remove the valve cover!
That's got to be worth big bucks now.
Liberator21 is offline
Old 08-11-2005 | 11:35 PM
hillbilly24's Avatar
Originally Posted by rmbuilder
Payton,
It’s possible these are not BBC manifolds. I have worked on some of the original factory cross ram intakes and these are virtually identical to the Chrysler Cross Ram setups (right down to the equalizer tubes) from the late 50’s and early 60’s. They were originally developed for the Speedways (300 series) and eventually made there way into drag racing. The Ramchargers ran them on their 413 wedge motors. In the 60’s some companies were running Mopar engines in marine applications. In those days Edelbrock would manufacture intake manifolds very similar in design to the factory pieces (Smokey Ram, BBC Mystery Motor ram intake). Some interesting history in these pieces.
Bob
Smokey Yunic was invovled with the development of that stuff and yeah the history is realy intersting. If you guys ever have the time you should pickup some books about him the guy was a geniuos. He basically invented the flow bench amingst allot of other things that we consider standard today. He was a hell of a charchter too.
hillbilly24 is offline
Formula29
3
03-31-2004 09:02 PM
SmallPP
3
01-15-2004 07:32 AM
BAD-HABIT
4
05-11-2003 09:05 PM
Raypanic
4
10-16-2002 09:32 AM
