Bravo 1 problems >
Bravo 1 problems
Bravo 1 problems
Old 08-10-2005 | 11:28 PM
vandeano's Avatar
Default Bravo 1 problems
When my bravo is in neutral and I turn the prop by hand left to right or right to left, I feel some play before you feel the gears have contact. Is this normal. I felt another out-drive and there was no play at all. I know that on a ring and pinion on a truck there is a small amount of play. Also, this out-drive has less then 20 hours on it. When I check the plug, no signs of water or metal. Any ideas?
vandeano is offline
Old 08-11-2005 | 02:08 AM
GOODT's Avatar
Default Re: Bravo 1 problems
Yes this is normal, The Bravo one lower does have a small amout of gear back lash.........
GOODT is offline
Old 08-11-2005 | 04:38 AM
vandeano's Avatar
Thanks, that was the word I was looking for "back Lash".
vandeano is offline
Old 08-11-2005 | 06:24 AM
GOODT's Avatar
Cool
GOODT is offline
Old 08-11-2005 | 10:18 PM
it all depends on how much "some play" is
bravos are supposed to have backlash but not too much, if the blade moves left or right no more than 1/8" to 1/4" then you shouldn't have much to worry about
davidwademarine is offline
Old 08-12-2005 | 12:22 AM
vandeano's Avatar
It is no more then 1/4. It was'nt as bad as I thought after I had some sleep....go figure.
vandeano is offline
satisfactionII
16
03-09-2008 08:21 PM
T-Mone
30
01-20-2006 07:13 PM
Feelin Nauti
10
02-29-2004 02:14 PM
edb07
21
12-28-2003 05:08 PM
Vinny P
3
04-20-2003 08:49 PM
