HELP with Bravo One - stuck in drive????
Anyone have a clue on this one? Someone put my friends boat in neutral while just coming off plane. The idle was prob at about 1500 ish which is about 500rpm higher that it would normally allow you to shift. That motor may have stalled. Not sure in that it happened too fast.
What is for sure is that the drive is stuck in Forward position. The stick won't go into neutral. It comes back only enough to bypass the neutral safety and allow the motor to start, but its starting in gear.
We tried rotating the prop by hand and it's stuck. Is the cone clutch somehow jammed? Any ideas on an easy way to rectify this?
Any help would be greatly appreciated he's supposed to go away on a boating trip in a few days.
Sounds like yo have welded the clutch to the races which are part of the gears. If that is the case there is no easy fix, you have to replace the upper gear set, yes all three gears have to be replaced cuase they are a matched set and that's the only way they sell them. To make sure this is the problem, pull the drive and see if you can move the shift link in and out with a pair of pliers if it won't budge the clutch is welded to the gear. You should also do a shift adjustment which has to be done with the drive off on Bravos. By pushing hard enough on the shift lever you have streched the cable and it will probably not shift right once you fix the drive if you don't do a shift adjustment. soory to be the bearer of bad news, but it is what is is.
I had a similar problem. Although I did not shift with the rpms high the drive did get stuck in gear. It turned out to be a broken shift arm in the upper drive case. The arm is located under the rear cover on the upper drive housing. It is an easy fix and the new part has been updated to stainless instead of aluminum. Drain the oil and take the rear cover off to inspect the shift arm. If it is ok you have other problems. If it is broke, the drive needs to come off far enough to disengage the shift cable. Then the arm can be replaced. Hope this helps and good luck.
Hey Hillbilly:
When you say welded, are you literally saying fused together? I'm not that familiar with the clutch, but how likely is it that its some how wedged together? Is it possable they could be seperated if they were'nt actually fused together?
I had the same problem stuck in gear earlier this year. A bolt fell off the shift arm. Thank god it happend in the driveway on the hose. Bolt did not get in the gears. Put it back on and away we went.
Originally Posted by CCPerformance
Hey Hillbilly:
Thanks for your help. We'll pull it today and see what happens.
PS, where is the cable adjustment once the drive is removed? Can't this be done from inside the boat?
CCPerformance
08-31-2005 05:48 AM
