Selecting Trim Tabs >
Selecting Trim Tabs
Selecting Trim Tabs
Old 09-08-2005 | 12:16 PM
Default Re: Selecting Trim Tabs
East Coast B > Did you ever mod that boat ? What motor/hp did it have ?
Unitek is offline
Old 09-08-2005 | 12:24 PM
East Coast B's Avatar
I did some mods and I'm still trying to forget about them.... took apart a perfectly good motor and it was never the same..... finally got the pros to put together basically stock again.... buddy had the 454 mag and was running 70ish with it... they are runners and hold tight to the water, always liked the hull. We went to a 26 and now the 31 wanting more cabin and a better ride...
Good luck!!!!
East Coast B is offline
Old 09-09-2005 | 10:39 AM
Although they are apparently not absolutely needed on this particular boat, I strongly believe that tabs will enhance the overall ride comfort of most any boat. Sticking the nose down just a bit makes wakes much less hard. Planing should require a little less effort and fuel also.
Even lightweight Bennett's would be nice on this boat.
deboatmon is offline
Old 09-09-2005 | 11:40 AM
Pat McPherson's Avatar
I agree with Ken.
Tabs can help any boat, especially in rough water.
A 4 blade prop may also help with the chine walking.
Patrick
Pat McPherson is offline
Old 09-11-2005 | 08:25 AM
I have a 22 Scarab and it takes a while to plain... I am hoping that Tabs will help with that
Longrange4u is offline
Old 09-12-2005 | 08:16 PM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
Personally, I wouldn't own a boat without trim tabs (yes, even if I didn't design and build them ) It just adds so much more control and flexibility to even the most 'well balanced' hulls.
Ironically, a gentleman from CA. with a 22' Scarab (soon to be featured in a major boating mag) ordered a pair of 15" Victorys today. He wasn't so concerned with his planing times, but as deboatmon and Pat eluded to, simply wanted to stop from getting 'beat up' in nasty poker run water. Dropping the tabs a little will allow you to knife through waves. (and believe me, the better half will thank you! )
Longrange4u- I feel your pain brother. It's troubling to say the least, looking at the horizon while waiting for the boat to come over on plane. Trim tabs will most definitely help this situation and will make your drive a little happier too while performing your holeshot.
Perhaps one of the best features of trim tabs (especially with todays' gas prices ) , is the ability to completely dial your boat's running attitude in for MAXIMUM fuel efficiency. Personally, I run a 23" Vic-tab system on the Martini and plane at ridiculously low speeds.
Brian
martiniboat is offline
26sonic
Sonic
8
06-23-2009 09:14 PM
dloftis
Baja
8
03-12-2009 08:08 AM
offthefront
03-19-2006 11:46 AM
Smitty
09-11-2003 02:46 PM
Hot Boat
17
03-31-2002 06:00 PM
