Need help removing lower unit on johnson 85hp >
Old 09-08-2005 | 04:41 PM
Default Need help removing lower unit on johnson 85hp
Hello, I'm new to this forum and boats in general.. I have a 17' boat with a 1977 johnson v4 85hp... My first boat and it needs a water pump change.. I removed all the bolts, and it won't come loose.. ive read where i need to unhook the shift rod, however im not sure if that pertains to this motor and where it is, i read under the carbs and i see what looks like the shift rod but i don't see a hex head screw or a way to release it... Please help would like to get it fixed for the weekend... Thanks in advance and hope this is posted in the correct section...
faster100 is offline
Old 09-08-2005 | 05:15 PM
mopower's Avatar
Toxic FORMULA
Default Re: Need help removing lower unit on johnson 85hp
I haven't had an OB since 1990 , but you could also try www.screamandfly.com they're the OB nuts
mopower is offline
Old 09-08-2005 | 05:17 PM
Thanks alot
PWRQWST
7
07-11-2006 10:32 PM
blownboat
11
09-16-2005 05:07 PM
Waterfoul
08-10-2004 06:54 PM
blue thunder
27
03-18-2002 06:34 AM
pmichael
03-06-2002 12:13 PM
