Need Twin Disc to Spicer Adapter >
Old 09-09-2005 | 02:45 PM
Steve H's Avatar
artselectricinc.com
Default Need Twin Disc to Spicer Adapter
I am converting my fixed surface drive boat to Arnesons. The old set up had the prop shaft bolted directly to the transmission output flange. New set up will be using a standard driveline between trans and drive. I need the adapter so I can bolt the spicer 1350 u joint bracket to my trans. I have had zero luck finding one so far. I will have one custom made if I have to. But there has to be one out there somewhere that would be much less than a machine shop. The Trans is a 502G? with a six bolt pattern output flange. any help would be apptrciated.
Steve Hixson
Steve H is offline
fishead
0
06-27-2003 05:09 PM
fishead
0
06-02-2003 07:03 AM
bck
2
04-28-2002 12:15 PM
