First Bravos >
First Bravos
First Bravos
Old 01-11-2006 | 07:40 AM
birdog's Avatar
Default Re: First Bravos
Buy a TRS & you can always upgrade to a Konrad...Buy a Bravo & you will always have a Bravo....Just my thoughts
birdog is offline
Old 01-11-2006 | 12:58 PM
formula31's Avatar
I run my 88 bravos with a hose attached to the top cap, internal bottle and fully flooded. Otherwise, I think they are stronger, cases and caps are thicker, shifters better, they supposidly had trouble with the clutches but never on mine. My upper gears are ready to be changed after a lot of severe abuse. I wouldnt be afraid of the early drives. The torpedo is shorter and you will need cones over 70.
formula31 is offline
Old 01-11-2006 | 01:14 PM
Big Block Billy's Avatar
Smile Re: First Bravos
I feel that the one with the shorter torpedo, made my boat faster than the newer style. Selling one to a customer, the only prob. is the corrosion that I'm cleaning up and welding and refinishing. Took quite a lickin' and grounded out and stalled the motor several times, hardly could get it off boat due to twisted input shaft. Oil was clean as new. BBB
Big Block Billy is offline
MILD THUNDER
Swap Shop
5
09-04-2008 06:27 PM
mike11
Prop Talk
4
07-12-2007 12:39 PM
t500hps
9
02-15-2007 02:03 PM
NICKM
05-18-2006 03:25 PM
mmwalters
Prop Talk
1
11-13-2005 07:47 PM
