crash/standoff boxes ?
The reason they were used was because:
1) they are capable of full power forward or reverse. So one engine doesn't need to be counter-rotated.
2) they have a built in 1.5:1 gear reduction.
3) they have a drop center, dow angle output which lines up with the drive.
A crash box has none of this, so give up on that idea.
Check with Huber, Bam, etc. they may have a solution for you.
Gary
Gary
BAM was recommending a ZF-80. Problem is fitment. The drive coupler is already probably as short as can be and the engines are pretty close to the front right now. I don't know how close because they aren't in the boat now.
Straight bottoms and flat decks
It looks like the dropdown from input to output shaft is 5.65 with the output being at a 10 degree angle. It looks like the distance from the front of the tranny(not including bellhousing) to the out put shaft is 9.1 inches.
Huber Marine's Phone # 225-927-6895
Great Choice.
SCS shiftable crash box
About $ 9g's per engine, it think that answers your question
SCS Shiftable Crash box link
Good luck
Cougarman
Great Choice.
Good luck
Cougarman
Arneson's a good choice. I'm sure they've put together lots of trannys for inline ASDs. Rik is on the board.
Again a crashbox wont work due to the issues above.
You may also want to check with BAM, Huber, etc to see if they can upgrade yours, or the 5000 series BW, Hurth, or can set up a drop center, gear reduction 72C tranny for that much HP.
Originally Posted by bck
Don't know where Huber is located, but you can't get through due to the hurricane.
Baton Rouge, LA
Spoke with them a few days ago they are open and up and running so keep trying.
Cougarman
Seems like the biggest problem with using a different tranny is getting the necessary drop. There is about a 5.65 inch drop from input shaft to output shaft, then the output shaft itself is at a 10 degree down angle. The Twin disc dealer is still looking into the possibility of using another one of their trannys. I did get a hold of huber, but at a different number. Will talk with them again later. The Arneson conversion is just too expensive for me.
