Water pump impeller broken. Help! >
Old 09-28-2005 | 03:51 PM
mats's Avatar
Default Re: Water pump impeller broken. Help!
Thanks all of you. I understand that the oil-cooler is more intricate than the other ones. IŽll concentrate one that one.
Mats
mats is offline
Old 09-29-2005 | 07:43 AM
Donman's Avatar
My power steering cooler is straight-through, nothing to catch anything. It`s a 1998 Bravo set-up. The cool-fuel system and oil cooler do have a screen like device in them. GOOD LUCK.
Donman is offline
Old 09-29-2005 | 08:00 AM
The pieces will get hung up in one of the coolers or the hoses leading to them, check and flush them all. Anything small enough to get thru the oil cooler will go all the way thru and out. I also had pieces in the intake hose between the drive and the raw pump. They fortunately just fell out when I put the pump end of the hose deep in the bilge. Don't worry about pieces in your engine, if any, they are so small they will go right thru.
Pismo10 is offline
Old 09-29-2005 | 03:30 PM
mats's Avatar
Hi
I have now got all the pieces out and changed the pump. As you said all the pieces stopped at the oil-cooler. It has a screen with 1-2 mm holes at the inlet. Anything that passes that , passes the whole engine.
Thanks again
Mats
mats is offline
Old 10-20-2006 | 10:42 AM
Originally Posted by Raceangel77
Hi
A real problem, but all is not lost. The first thing I would do before you start taking anything apart is to try and back flush the engine with a hose pipe. Also if you can put some water descaler in the engine and let it sit for a while ( like Calgon full name sodiumtripoly phosphate or water softener to you and me! .Yyou can get this for home central heating from homedepot ) this will help to decalcify the inside and create less friction or even loosen lodge impeller parts. This is a good thing to do anyway like your home central heating system.
This method assumes that if it is stuck on the way in it should be able to get back out. A trick I have learnt is to try and pulse the water going in by putting a kink in the hose then letting go. Do this several times. Try and collect all the parts to see how much you have. If most of the parts are large then you could assume that smaller parts may have passed through.
Hope this works it has for me in the past.
Good luck jules
Oh yes discontect the pump
ps This is why KPM developed that run dry pump
This is why we make the run-dry impeller. Email me directly at
[email protected]
Matt
mwk4619 is offline
jonyb
WKYPA
15
08-17-2007 04:54 AM
jonyb
TN Powerboat Club
0
07-30-2007 09:16 PM
East Coast B
15
06-17-2005 03:05 PM
Lmarth
1
05-14-2005 10:29 PM
paradigm shift
16
11-02-2004 09:17 PM
