Dimension on #6 drive >
Old 10-11-2005 | 07:12 AM
rv
Default Dimension on #6 drive
Could someone tell me the distance from the prop shaft center to the bottom of the cavitation plate on a #6 drive.
I am trying to determine what is acceptable for distance between prop tip and bottom of cavitation plate. I assume 18" props would be the largest for the #6.
Thanks,
Rick
rv is offline
Old 10-11-2005 | 09:40 AM
Default Re: Dimension on #6 drive
I'm watchin you...
Back4More is offline
Old 10-11-2005 | 10:13 AM
Brad Zastrow's Avatar
That sounds about right. I can measure mine tonight. I assume nobody makes prop bigger than will fit a six.
Brad Zastrow is offline
Old 10-11-2005 | 10:41 AM
rv
Mark,
I am thinking about making a spacer for our #5's that has a cavitation plate like the #6. It is a little scary looking down in the water from the swim platform.
Brad, thanks let me know what you find out. As long as you have the tape out could you also tell me the width of the plate over the prop.
Rick
rv is offline
Old 10-11-2005 | 12:19 PM
Pwrbt33's Avatar
I was pretty sure but I had to check to be safe, the measurement from the bottom of the cav. plate to propshaft centerline is 9.5". As far as the width of the ventilation plate it is tapered. The end is 6" and 11" in from the end of the plate is 9".
Hope this helps everyone out.
For anyone interested, we have a set of empty polished gearcases for sale. #6 dry sump's. The skegs have been cut narrower but the stock length is still there. Email me if you need pictures or more info.
John S.
Oh ya, the cav. plate on the #5 measures 6 1/8" if your not near your boat.
Attached Thumbnails Dimension on #6 drive-6-drives-2.jpg   Dimension on #6 drive-6-drives-4.jpg   Dimension on #6 drive-6-drives3.jpg
Pwrbt33 is offline
Old 10-11-2005 | 02:15 PM
rv
Isn't OSO great! Thanks, Pwrbt33 for all of this info and then some. That is exactly what I was looking for.
Rick
rv is offline
Old 10-11-2005 | 03:41 PM
Pwrbt33's Avatar
no problem! Need any other info just email me.
John S.
Pwrbt33 is offline
Old 10-11-2005 | 08:21 PM
My measurments are the same. My 17.25 props leave 3/4 inch of room.
Old 10-12-2005 | 07:24 AM
rv
Thanks Brad.
Rick
rv is offline
Elite Marine
Pantera
5
10-10-2006 05:20 PM
KCHOTBOAT
9
07-05-2006 07:55 PM
Elite Marine
Pantera
12
08-19-2003 09:14 AM
jonesj
06-12-2003 03:24 AM
mxz800
Checkmate
12
01-17-2002 11:24 PM
