Which spark plug wires for 454 mag? >
Old 11-01-2005 | 07:31 AM
zimm17's Avatar
Default Which spark plug wires for 454 mag?
I'm looking for new wires for my '96 454 mag (thunderbolt V IGN). I like the big MSD wires. Anyone known what part number I need to get the proper lengths to route around the back and under the exhaust manifolds? Do standard big block chevy wires work?
zimm17 is offline
Old 11-01-2005 | 07:40 AM
Official OSO boat whore
Default Re: Which spark plug wires for 454 mag?
Almost any decent performance wire will work fine. The big fat wires are not necessary (but do look better). Just make sure you get the resistance core wire. I like to make my own wires up as I can get the lengths just right and eliminate the spagetti. I also tie my wires up very well using zip ties. There is a pretty slick method using 4 zip ties. You loop the one tie around all the wires and then use additional ties to separate each wire. Tighten them up and you are ready to go.
Cord is offline
Old 11-01-2005 | 01:46 PM
Strip Poker 388's Avatar
Rob
Napa has a good Beldin wire .They make a set for that motor and get them to cross it over to the regular line it will be cheaper than the marine vers.They have a lifetime warrenty also.
MSD sells a set for about 75.00
Teague has some for 47.50 ???? Becarefull of them
Strip Poker 388 is offline
Old 11-01-2005 | 11:45 PM
Taylor plug wires are excellent. You can order them through Summit. The come in a variety of colors as well and are available in cut to length kits.
Griff is offline
Old 05-27-2006 | 10:53 PM
SOX's Avatar
SOX
Semper Fi
Just found this doing a search, Is there a difference between regular car wires and marine wires? How about distributor caps. I want to change my old 8mm wires to a set of red 8.5mm wires and replace the cap with a red as well. Will I have any problems with just buying a set off of Summit racing's web site?
Attached Thumbnails Which spark plug wires for 454 mag?-joey-4-30-06-green-fields-show-041-medium-.jpg
SOX is offline
Old 05-27-2006 | 11:02 PM
cuda's Avatar
I bought a set of Summit wires. They weren't long enough to go under or around the exhaust. I ended up buy a set of Moroso's that you make up to length.
The Summits were beautiful though. I may end up using them on an SBC.
cuda is offline
GK
4
06-26-2008 07:45 AM
gripit
7
04-01-2007 09:57 PM
speed demon
3
06-29-2005 11:27 AM
97BossHammer
5
02-12-2004 02:57 PM
puder
2
08-31-2002 11:25 PM
