bravo xr
Old 11-03-2005 | 03:56 PM
KRAZYKATZ's Avatar
Default bravo xr
what is the best price for brand new xrs
who has them.
thanks.
greg.
KRAZYKATZ is offline
Old 11-03-2005 | 05:07 PM
NJSONIC's Avatar
Default Re: bravo xr
Greg,
Call Mindi Doller at Doller offshore. Tell her you are an OSO member. 954-237-0332,or 800-376-1616. She will take care of you.
Tom
NJSONIC is offline
Old 11-03-2005 | 05:12 PM
drypipetiger's Avatar
What is the going rate for the old version of the Xr with low water pickup? I'm also in the market.
drypipetiger is offline
Old 11-03-2005 | 09:08 PM
Mbam's Avatar
Offshoreonly Advertiser
The 4 we have are low water pickup, I need to update the ad. Also have the new style on the shelf.
Mbam is offline
Old 11-04-2005 | 05:34 PM
KRAZYKATZ's Avatar
do you take trades.
Old 11-08-2005 | 06:38 AM
Quiet Storm's Avatar
What's the difference?
Quiet Storm is offline
Old 11-08-2005 | 01:19 PM
Downtown42's Avatar
ones newer sorry!!
Downtown42 is offline
Old 11-08-2005 | 02:27 PM
Does the newer version of the XR bolt right on to the original ITS? Or has the ITS styling also been changed? If I need to replace my original XR on my ITS, what are the advantages to the newer XR other than case styling over the original XR that is discounted?
zahndok is offline
Old 11-08-2005 | 05:47 PM
Mr Gadgets's Avatar
Charter Member #601
zahndok,
The new design uses a different method for shiming the gears in the case. The clutch is suppose to be different also, but I dont know that for a fact. I just build them with the newest parts from Merc..
The ITS has a longer input shaft, so the regular XR wont just bolt up. Merc has changed the input shafts to a metric ujoint and you cant mix and match. It would have to have the proper input shaft, for the ITS, when it is built. Or it could be switched after it is built.
Hope that helps.
Dick
Mr Gadgets is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
