Ignition breaking up off idle to 1600 RPM >
Old 11-16-2005, 04:53 PM
Default Ignition breaking up off idle to 1600 RPM
Another day, another mystery.
My right engine has a problem with the ignition just off idle and up to about 1600 RPM where the advance kicks in. The idle is perfect but as the power is advanced off of idle after about 1000 rpm I get a nasty stumble and roughness in running kind of like a chug chug chug.....After 1600 RPM under load or not the engine smooths out and runs fine as soon as the advance takes over. This problem has existed since day one on this rebuilt engine now with 28 hours.
I put my timing light on the marks and at full idle they are steady at 12 degrees. As I touch the power open the mark jumps sometimes retarded, and sometimes advanced from the idle of 12 degrees, each by about 2-3 degrees. With slightly more power (around 1000 RPM) the mark will jump from 14 degrees advance to 8 degrees and jump back and fourth between the two. After the advance module (v8-HP) kicks in the mark steady's throught the entire advance curve and thereafter.
I clipped my timing light lead onto each plug wire and all were showing a intermintent light pattern in the troubble zone on power. Nice smooth steady flashing at idle and into advance.
I switched modules, wire harnesses to the modules, new caps and rotors, new sensor, new coil, new coil lead wire, checked all grounds, etc without change. I'm thinking the gear to the distributor worn or a problem with the camshaft. (supposedly new). I'm not sure if the mechanic replaced plug wires or not but they don't really look new, and they seem fine at higher and lower power than the trouble spot.
454's (basically stock MCM 420's) thunderbolt IV ignition, 8mm wires etc etc)
Any ideas on this one? I am hoping this is the last problem for a while. (especially since I will be putting it away in a week or two.)
stinger390 is offline
Old 11-16-2005, 05:21 PM
Geronimo36
Panther's Avatar
Default Re: Ignition breaking up off idle to 1600 RPM
Swap coil and iginition modules (one at a time) from one engine to the other.
Since you've been having ignition problems previously I would start there to be sure.
Panther is offline
Old 11-16-2005, 06:06 PM
cuda's Avatar
Accelerator pump?
cuda is offline
Old 11-16-2005, 08:31 PM
Already swoped coils, modules, harnesses, everything....
Problem seems to definitely be ignition related, not carburation. Timing is all over the place from about 1000 RPM through 1600 RPM where the advance module stabalizes it and the engine runs normally.
Old 11-16-2005, 08:32 PM
formula31's Avatar
Originally Posted by cuda
Accelerator pump?
Yea, I gotta think that at this point too. Look at squirt quantity and quality, dont burn your eyebrows off (having done that myself too many times)
formula31 is offline
Old 11-16-2005, 08:37 PM
formula31's Avatar
Hmmm, could the cam be walking? Flat tappet I assume. They usually are stable to the block due to load from the oil pump. Hmmm, oil pump harmonic causing the cam to dist gear to load and unload? Just thinking wildly now.
Old 11-16-2005, 09:40 PM
Liberator21 is offline
Old 11-16-2005, 10:25 PM
racin fever
check your wires on the dist, grn wht red wht are switched ?
Old 11-16-2005, 10:29 PM
swap the whole distributor into the good known engine,dont bother with bits and pieces,if the dis shaft is worn in the housing,the rotor will wobble and timming and ignition will not be accurate!
JJONES is offline
Old 11-16-2005, 10:40 PM
monstaaa's Avatar
depending on the cam, the gear may be the wrong gear and she may be lashing on you. also if the distributor is of the adjustable height type like an msd , that same prob diff reason. more t han likely th pickup is on its way out. have seen it a couple times with an msd distributor.
good luck.
monstaaa is offline
Quick Reply: Ignition breaking up off idle to 1600 RPM
