Drive Storage, Up Or Down >
Old 11-18-2005 | 09:37 AM
88formula223's Avatar
NO WAKE ENFORCER
Default Drive Storage, Up Or Down
Should The Drive Be Stored Up Or Down For The Winter?
88formula223 is offline
Old 11-18-2005 | 09:39 AM
OldSchool's Avatar
Default Re: Drive Storage, Up Or Down
Down...storing it in the up position will mess up the bellows.
OldSchool is offline
Old 11-18-2005 | 09:43 AM
NO WAKE ENFORCER
thats what i thought just second guessing myself, belows are newer, I don't want to mess those up
thanks
Old 11-18-2005 | 11:20 AM
Iggy's Avatar
Doesn't matter what time of year it is, I always lower my drive to keep the bellows from stretching.
Iggy is offline
Old 11-18-2005 | 01:19 PM
Downtown42's Avatar
ditto...it's in the merx book >>> Down boy, Down..
oh yeah, I tag my hitch on trailer warning any moron that needs to move the rig with a forklift, not to raise too high so the skex don't drag. Always gotta be thinking...
Downtown42 is offline
Old 11-18-2005 | 01:42 PM
NO WAKE ENFORCER
good idea, where I keep mine at you just drop it off then they put it away so I'm going to have to let them know that it is down
Old 11-20-2005 | 12:54 PM
Thumbs down Re: Drive Storage, Up Or Down
down as low as you can go
JJONES is offline
Old 11-20-2005 | 10:07 PM
Mine is always off the boat and stored inside. Check the allignment and install in the spring.
Padraig is offline
Old 11-21-2005 | 12:27 PM
All the way down for three reasons
1. Any water trapped in exhaust area ( carrier) of the drive
could freeze and split drive (if outside rain / snow)
True for Outboards as well as I/O's
2. The trim pistons rams are in the cylinders and keeps them
from rusting
True for Outboards as well as I/O's also
3. The bellows are in a more neutral state less stretching
This is a fourth reason than ive seen once
Any water in Drive oil will settle to bottom rather than
around gears and bearings in the thrust end . But you
should change Drive oil before winter storage just so you
know if you have a problem.
Daddio
Daddio is offline
Ona-Mission
Do It Yourself, Boating on a Budget
4
07-07-2008 12:11 PM
Canada Jeff
Drives and Lower Units
10
07-19-2007 02:38 PM
mwdill
06-27-2006 08:44 PM
thayes11
0
10-02-2005 12:36 PM
panteraracin
3
02-07-2002 10:36 PM
