Trying to be ready for next season. >
Old 11-26-2005 | 04:49 PM
Default Trying to be ready for next season.
OK....this past summer was my first summer with a boat. I had alot of problems with it this summer and hope to have all the bugs worked out so I can actually enjoy it next season. Like I said I am new to boating. I had alot of overheating problems. Changed out the Raw water pump and T-stat. And still getting hott. When I get up to about 4R's It will run for a short time and throttle will cut out. Come off of the throttle and the boat is still running. Weirdest thing. Does anyone know what this may be a sign of. Oh I am running a Merc 502 EFI with Bravo 1 drive. Looking forward to next season.
27Avanti502EFI is offline
Old 11-26-2005 | 05:16 PM
axapowell's Avatar
Where To
Default Re: Trying to be ready for next season.
The engine (ECU, computer) goes into safe mode or "limp Home mode" which will allow for low RPM running to get you back to shore. On the overheating thing, check all your hoses for a blockage, the I'd do a compression test to make sure you don't have a blown gead gasket. Any white smoke or excessive steam from the exhaust? What does the temp gauge say?
axapowell is offline
Old 11-26-2005 | 05:39 PM
velocitypwrbtr's Avatar
It's your money. Pull it now or pull it later. There's something internally causing excessive heat.
velocitypwrbtr is offline
Old 11-26-2005 | 06:07 PM
Vinny P's Avatar
I hate the winter!!
I would check that the manifolds and risers are not clogged up. Usually, they act just like the problem you are describing..
Vinny P is offline
Old 11-26-2005 | 09:27 PM
t500hps's Avatar
21 and 42 footers
Did you change the circulating pump or the Impeller kit? Sound like you could have impeller pieces inside the passages somewhere. (I did but we were able to back flush them out)
t500hps is offline
Old 11-27-2005 | 01:05 AM
ratman's Avatar
best way to get ready for next year is to freshen up the motor and add more doggies, and build a spare while your at it...you might want to get a spare drive as well
ratman is offline
HuronRiverRat
Chris Craft
11
05-14-2007 09:33 PM
Superbabi
Superboat
76
05-14-2007 08:12 AM
DRIVEN1
06-10-2006 04:23 PM
27Avanti502EFI
6
10-17-2005 04:42 AM
Ron P
04-09-2005 03:54 PM
