oil pump selection >
oil pump selection
oil pump selection
Old 12-04-2005 | 10:44 AM
Default Re: oil pump selection
I would probably try to avoid the merc pump. I know the pump they use on the 500efi and 525efis have the gasket under the top cover. In my mind this is something I always avoid and replace with a better quality pump that is a machined fit. Such as Melling. I am not sure who makes these pumps I would assume it is a GM part #.
Cam-shaft is offline
Old 12-04-2005 | 10:48 AM
PatriYacht's Avatar
The Melling punp is about 40.00 from any auto parts supplier. I hate to think what Mercruiser sells it for, probably a couple hundred. Go with the Melling and a new pick up. Weld or braze the pick up.
PatriYacht is offline
Old 12-04-2005 | 04:12 PM
Tack weld with NI-rod. Brazing with torch makes too much heat before the bronze flows. --- Jer
jpclear is offline
Old 12-05-2005 | 12:43 AM
Big Block Billy's Avatar
Smile Re: oil pump selection
M77 Hv . Do yourself and your motor a favor and deburr the gears inside on a wire scratch wheel or file by hand. This will help keep the pump from wearing itself out. BBB
Big Block Billy is offline
Old 12-05-2005 | 10:25 AM
By using a high volume pump do I have to worry about high pressures and stock clearances. I have got the block assembled and balanced so opening up oil passages is out. What is a NII rod in welding? Will a wire fed mig do?
team Tickfaw is offline
Old 12-05-2005 | 11:02 AM
Mig is no good for that. Ni rod is nickel. Pump manufacturers suggest taking the pump apart to weld, I have good luck just tack welding with a 55% nickel rod. Forney sells a good rod and you can get 'em at any Ace hardware. for apx $5 for a pack of them. Also make sure you use a big enough pan in order not to pump all the oil out of the pan before it returns back down. BBB
Old 12-05-2005 | 11:31 AM
Question Re: oil pump selection
I will be using the stock stamped steel oil pans. When starb. motor left it took the 14 qrt oil pan with it. After pricing these I decided to run the stock pans on both new engines. Everything is starting to come together now but at the point of selecting oil pumps. I was told not to run high volume if I had not opened up oil passages. Any insight on this?
Old 12-05-2005 | 07:12 PM
axapowell's Avatar
Where To
The oil pump number I gave you is high volume and stock pressure. All I've ever used with no issues. Big or small block.
axapowell is offline
joeboff
Do It Yourself, Boating on a Budget
7
05-08-2008 04:06 PM
djtalon
2
08-06-2007 10:20 AM
alecsammy
6
03-28-2007 12:00 PM
BeakBoater35
4
08-29-2005 08:33 AM
