gil offshore exhaust riser gaskets >
Old 12-13-2005 | 07:39 PM
Default gil offshore exhaust riser gaskets
Is it possible for this gasket to give you that I just popped two head gaskets feeling if the riser / manifold gasket goes bad . I thought no water went thru the gil manifold ./ riser connection . Just thru the hose .
boatman747 is offline
Old 12-13-2005 | 08:12 PM
axapowell's Avatar
Where To
Default Re: gil offshore exhaust riser gaskets
My Gils do NOT have water between the riser and manifold gasket (circa 1999). As you said, there are hoses which supply the water from the manifold to the riser. I would say NO. Could you have cracked a manifold and it is allowing water to mix with the exhaust early...Yes thus causing some blown head gasket symptoms.
Hope it helps and good luck!
Dave
axapowell is offline
Old 12-13-2005 | 09:31 PM
plumbers crack's Avatar
Talking Re: gil offshore exhaust riser gaskets
They crack very often.If they are the short sweep version ,and you have modified the motors.You could have a case of reversion.Pressure test them,they run dry to the ends.Pull center plugs on 1 bank see if you have water laying in them.
plumbers crack is offline
offthefront
Wanted
0
01-15-2008 01:02 PM
THE BULL
08-27-2002 10:02 AM
Jayl13
3
07-03-2002 10:38 AM
Wally
06-28-2002 12:43 PM
FlyFast
3
04-30-2002 06:37 PM
