Crane Rocker Studs >
Crane Rocker Studs
Crane Rocker Studs
Old 12-18-2005 | 10:34 AM
Default Crane Rocker Studs
What is the proper torque for the big block studs?? Use oil or lock-tite during install??
TROUBLE MAKER is offline
Old 12-18-2005 | 10:45 AM
Default Re: Crane Rocker Studs
60-65 lbs make sure to use sealant on the intake studs sometimes they go into the port.
MESABALANCING is offline
Old 12-18-2005 | 03:59 PM
Are you sure your not talking about the head bolts??
Old 12-18-2005 | 04:03 PM
Pwrbt33's Avatar
Talking Re: Crane Rocker Studs
Nope, he's not. He is talking about the rocker arm studs in the cylinder head. If you look close some of the threads go into the intake runner of the head. It may only be 2 but you should do them all the same way.
John S.
Pwrbt33 is offline
Old 12-19-2005 | 09:23 AM
BajaBennett's Avatar
Thinking of making the same changes to my 502's. What kind of sealer sould be used?
Thanks,
Dail
BajaBennett is offline
Old 12-24-2005 | 10:45 PM
Thanks............
Old 12-25-2005 | 12:31 AM
axapowell's Avatar
Where To
I've always used Permatex High Temperature Thread Sealant with teflon. Seems to do the trick.
axapowell is offline
Old 12-25-2005 | 01:47 PM
ARP studs we torque to 60 ft lbs. The ARP thread sealer works well and usually only has to be installed on the intake studs , but sometimes with aftermarket heads the bolt holes are drilled to deep. You should check and make certain they are "blind" on the exhaust . Permatex 3-H sealer also wprks well. Loctite should NEVER be used internally on an engine! Threads are designed a specific way for a reason...To Fasten.
mrhorsepower1 is offline
Old 12-26-2005 | 04:00 PM
Thumbs up Re: Crane Rocker Studs
Your good at 60 pounds. I use thread locker if their aluminum OR cast iron heads. CanDo
CanDo is offline
Old 12-26-2005 | 11:21 PM
Are you guys talking about 7/16 or 3/8 studs??????
I know mine are 3/8 bottom and 7/16 top and the ARP directions said like 40 or 45lbs. I used red locktite.
Griff is offline
DDDonzi
5
06-08-2008 07:09 PM
Ken N
1
02-09-2008 09:46 AM
Ken N
12
02-08-2008 01:10 PM
SkiDoc
3
05-01-2005 08:56 PM
timucin
1
12-18-2003 02:08 PM
