innercooler hose routing >
Old 12-18-2005 | 07:08 PM
johnnyboatman's Avatar
Default innercooler hose routing
fixing to start installing my cooler was wondering if anyone has any pics of how one should be plumbed?
johnnyboatman is offline
Old 12-18-2005 | 07:36 PM
Default Re: innercooler hose routing
they are actually superchillers was wondering what size hose and fittings?
Old 12-18-2005 | 08:23 PM
KNOT-RIGHT's Avatar
On my V hull I ran 1 inch adjustable Hardin marine thru hull
pickups to gate valves 1 /14 hose to a sea strainer then # 12 feeding the intercooler then #16 dump out the front to thru transom dumps. Its nice to dump them on the side so you can see it. I also ran 1/4 inch bleed offs from the back of each
head to a tee to a 1/8 inch fitting feeding warm water into
the back of the intercooler.
1 pound per pound of boost good rule of thumb.
I have gauges reading presure on the intercoolers.
This method insures flow only when moving. The ajustability
of the pickup enables the increase or decrease of flow and
pressure.
This way worked well for me running 8 to ten lbs boost
on a v hull. Single stage sea pump with richard lee intercoolers. Full water jacketed tubular headers dry.exhaust
Gerry
KNOT-RIGHT is offline
Old 12-18-2005 | 08:41 PM
KNOT-RIGHT's Avatar
Now on my Cat I only want to run one pickup per engine
not two like above.
There are two ways I am considering.
One pickup gate valve 1-1/4 hose to large sea strainer
with two outputs one going to the single stage sea pump
feeding the engines. The other going to 1 inch check valve to
# 12 to the intercooler then # 16 dump.
Or maybe the better way One pickup, gate valve 1-1/4 hose to large sea strainer then to a triple stage pump
one stage feeds one side of engine the second stage feeds
the other side of engine. The third stage feeds
the intercooler. The only thing I dont like is it will feed water
at Idle. Most likely will need a gate valve to regulate
the presure to a tee dumping the excess over board.
Have I confused you yet?
Gerry
Old 12-18-2005 | 08:44 PM
KNOT-RIGHT's Avatar
Oh yeah dont know if ya run in saltwater.
Just back flush the thru hull to rinse the intercoolers.
The engine flushing is taken care of via the gate valves
on the pickups with hose fittings teed after and before sea
pumps.
Old 12-18-2005 | 08:46 PM
any pics?
Old 12-18-2005 | 08:47 PM
just doing innercoolers still cooling motors with sea pump
Old 12-18-2005 | 08:49 PM
fresh water only
Old 12-18-2005 | 08:58 PM
KNOT-RIGHT's Avatar
Sorry no pictures
Boats shrink wraped and its 6 degrees outside
What is your boat ?
Old 12-18-2005 | 09:23 PM
Do A Search On This,I Just Did This Hole Project And Even Posted Pics!S ome Body Else Was Doing This On 525sc And Alot Of Info Was Given!was It Infact You?I Cant Remember But There Is Alot Of Threads On This!good Luck!
JJONES is offline
