454 mag head and cam selection >
Old 01-18-2006 | 08:45 PM
I have twin 454 mag efi s 385hp. I want to put a set of aluminum heads and upgrade the cam and put on some headers. Any suggestions??? Ive looked at the afr 315 cc heads CNC runners. Is that a good choice for my motors? Thanks for any advice. Want to pick up some good power gains.
obsessioncatsass is offline
Old 01-18-2006 | 09:07 PM
Pat McPherson's Avatar
Default Re: 454 mag head and cam selection
Talk to Tyler Crocket. He has upgrade packages for EFI/MPI engines.
You will need to have the ECMs re-calibrated for more than just an exhaust change...
Patrick
Pat McPherson is offline
Old 01-18-2006 | 09:14 PM
KAAMA's Avatar
obsession,
A set of heads with s smaller runner size would probably be more suitable for a 454cid marine engine vs a set of 315cc runners. There are several guys on here who are running the 315 AFR heads on 540cid engines---some even with blowers. I run the 315 AFR heads on my naturaly aspirated 565cid engines.
There are some guys on here that you can get some good ideas from. At least one of them is "rmbuilder"/Bob Madara. He's a man of integrity and is a very good, knowledgable guy to ask. He has helped several guys on here, and can help you select the right head, and cam combination for your cubic inches, rpm range/application.
KAAMA is offline
Old 01-19-2006 | 07:15 AM
Originally Posted by KAAMA
obsession,
Bob has helped me a time or two...
Patrick
Old 01-20-2006 | 07:37 AM
QUIKDECISION's Avatar
I too will vouch for Bob. RMbuilder... He was a wonderful help when i was rebuilding my 454 mags. One of the Best....
QUIKDECISION is offline
jmorriss103
01-08-2008 07:57 AM
obsessioncatsass
2
05-15-2006 06:36 AM
QUIKDECISION
8
01-14-2006 02:40 PM
chromecat
2
06-05-2005 02:13 PM
Cat-n-Around
2
07-22-2003 04:44 AM
