Boat Bling
Old 01-22-2006 | 06:19 PM
375stinger's Avatar
Default Re: Boat Bling
also, can you make small aluminum cup holders that are an inch shorter than normal? thanks, i need 7 i think
375stinger is offline
Old 01-22-2006 | 06:31 PM
375stinger's Avatar
also i wanted to make some custom billet air scoop mesh thingys....i want them to be shiny billet w/ a bunch of air holes and also somehow incorporate the cigarette oval logo in them. heres a pic of what used to be in the air scoops thanks
Old 01-22-2006 | 06:36 PM
375stinger's Avatar
you can kinda see the scoops built into the back part of the hatch, i will try to get better pics and dimensions soon. also, we are going to be adding air scoops for the blowers, and would like the pattern to continue and make the same things that could fit in the intake to them..
Old 01-22-2006 | 06:42 PM
375stinger's Avatar
looking at some scoops like this, because they kind of go with the rear built in scoops if ya look at them from the side.
Attached Thumbnails Boat Bling-hood-scoop-cig.jpg   Boat Bling-picture-021.jpg   Boat Bling-picture-026.jpg
Old 01-22-2006 | 07:55 PM
monstaaa's Avatar
none of this should be a problem.
first , you said no holes in the panel but the screwholes. then move compas and"screw holes". a little un clear. not to worry. we would ask that you describe in detail exactly what YOU WANT. give us demension's. logo's, any other important criteria. we will design the art work. send it to you. upon approval of art work and agreement to price we fabricate item's needed to satisfaction.
if it is a dash panel, we can pre-wire it for you as well. also finish it. powder coated, air brushed to match graphic's, what ever. also can be engraved.
p.m me if you'd like with your phone number or call me this week .
516-799-6029.
thanyou for your interest. Bo
monstaaa is offline
Old 01-22-2006 | 08:00 PM
monstaaa's Avatar
p.s here's a small sample of a prefab panel we wired. also another set that we airbrushe to match the graphic's on the boat.
Attached Thumbnails Boat Bling-p1010033.jpg   Boat Bling-cnc-parts-018.jpg   Boat Bling-cnc-parts-019b.jpg
monstaaa is offline
Old 01-23-2006 | 01:03 PM
JasonSmith's Avatar
I need a bezel to go around my Keikefer (sp) shift quadrant. Nobody makes them.
JasonSmith is offline
Old 01-23-2006 | 03:10 PM
Payton's Avatar
Charter Member #927
How about an engine oil cooler that looks good enough to leave simply polished, that will mount on a sringer or bulkhead with a slip plate arangemnt. A single bolt to hold the slip plates together so the engine can be removed with out breaking any lines. Maybe a filter and or thermostat incorporated as well.
What you've made looks great.
Payton is offline
Old 01-23-2006 | 06:09 PM
offthefront's Avatar
the Damn is cracking ......
offthefront is offline
Old 01-23-2006 | 09:09 PM
monstaaa's Avatar
great suggestion's , keep them coming. it help's hone idea's to make or come up with useable item's. going to sart working on some of these ideas. and thank you for the possitive comment's, there greatly appreciated.
monstaaa is offline
