Forward Ballast ? >
Forward Ballast ?
Forward Ballast ?
Old 01-22-2006 | 06:22 PM
offthefront's Avatar
Default Forward Ballast ?
39 KRYPTONITE losted on OSO .... list forward Ballast ?
http://www.offshoreonly.com/esvon/page-8030.html
offthefront is offline
Old 01-22-2006 | 08:23 PM
monstaaa's Avatar
Default Re: Forward Ballast ?
the boat has a forward ballast tank in it, which is permanently glassed in. actually its pretty trick, theres an electric dump opperated v.i.a a switch on the dash to the right which dumps the tank. and to fill it , it has, which i believe is the first such use in this industry, a remote electric ball valve that is opperated from the same panel where the dump switch is located. i did some work on this boat for kirk as a sub a while back.
monstaaa is offline
Old 01-22-2006 | 08:46 PM
What does it do?
MILD THUNDER is offline
Old 01-23-2006 | 07:24 AM
monstaaa's Avatar
add's balast when needed to keep the bow down in certain sea condition's
monstaaa is offline
Old 01-23-2006 | 12:13 PM
The 311's have a porpise problem that I have thought about moving some weight forward. I know I did it in a Welcraft I had .. lead weights in the bow . I know it would compromise some speed at times but might be a simple fix. there has been alot of disscussion in the prop section about what prop would sovle the isssue ......m
Old 01-23-2006 | 12:39 PM
Shore Thing's Avatar
Is that the same type of system that wakeboard boats have been using over the past 10 years, just placed in the bow instead of the stern?
Offthefront, you may want to look into what some of the wakeboard boats use. I believe there are portable units as well.
Shore Thing is offline
Old 01-23-2006 | 09:40 PM
monstaaa's Avatar
the lead weights arent such a good idea from a safety standpoint, especially if they were to come loose after a violent impact or so.
as far as compromising speed that is questionable. for example 24 skater w/2.5's v.s 28 skater w /2.5's. the bigger heavier boat is faster with the same power. it tends to carry it's weight better while maintaining a better c.g . so sometimes weight actually help's, especially if it can be added or moved to a specific area.
some rops do help with this also. helping to lift stern and such. had alot of luck with the 5 bld max from merc. more than anything it takes alot of time to accurately dial in any boat for optimum all around performance.
monstaaa is offline
Old 01-23-2006 | 10:44 PM
CcanDo's Avatar
A ballast tank is a simple method of fine tuning your C.G., while running.Subject to changing load (fuel on board,passengers,passenger placement and etc.) water in the ballast tank effects the C.G. relative to those variables.Example:10 gallons x 8lbs./gal=80lbs......80#x30 ft.=2400# lever arm from the transom.Big number,with enough wt. up front it might be easy to stuff the bow. Good Luck
CcanDo is offline
CcanDo
03-30-2008 02:45 PM
Hot Boat
General Racing Discussion
10
03-15-2006 11:05 PM
Jolley
10-05-2002 10:30 AM
olysan
20
08-01-2002 01:25 PM
jbrauer
02-26-2002 08:30 AM
