Pressue relief valves?
Originally Posted by US1 Fountain
The ones from Mercury must be good. At least for over $200 for a peice of plastic, one would assume so.
What size hose is used for the dump?
Thanks,
Kurt
kurt the mercs use a 1" hose to bleed off the water pressure quickly, the other vaalves are for biolers and are not the best setup the mercs work prefectly
those are the kpm valves i think sterling is using them and the kpm 2 stage pumps on their supercharged engine packages. they use a 3/4 hose i think
Originally Posted by ratman
back for more, yes i have the mercs. rm
I tried to e-mail you and PM you but you have blockers inplace.
I just had the Mercury valves installed. The builder said they fit better than the others would? They were $290 each! He cut the springs to allow about 12 psi through. I hope this will be enough?
