Pressue relief valves? >
Old 08-15-2006 | 03:43 AM
  #51
Default Re: Pressue relief valves?
Jerry, how did you do?
With them just as is Im running at 12psi with bumps to 15psi....the water was 2-4's... so a smooth water run/test is still set for Wed.
Back4More is offline
Old 08-15-2006 | 04:11 PM
  #52
US1 Fountain's Avatar
Ginger or Mary Ann?
Mine were right at 20 psi max with the new springs, uncut. 1 motor will run a bit higher pressure until the valve is fully open, then it matches the other motor. I think my t-stat may be part of that condition. I cut 1 coil off 1 of the springs, but never ran it yet, just to see what happens. 1of the dump hose has a fast pulsating to it. The other is smooth, perfect.
All in all, I'm good to go with them uncut. What a huge relief this is. No more 50psi pressure. Down side is, I ran thru alot of gas Sat, now that I can run.
US1 Fountain is offline
Old 08-16-2006 | 08:34 AM
  #53
Yeah, Same here...
Old 10-10-2015 | 07:06 AM
  #54
Ginger or Mary Ann?
To the top for Easyrider
Ran-Dom 32
Wanted
0
05-04-2008 07:29 PM
ROADHOG
1
02-04-2006 01:18 PM
tj309
1
04-07-2005 08:30 PM
Bill272
2
07-22-2002 05:35 PM
US1 Fountain
30
07-01-2002 12:24 PM
