small block roller conversion
Originally Posted by 245 limited
I was asked if my block was drilled and tapped before,I did not even think of looking last year when i had the intake off,I should go pull the intake to see.I know his engine was in a 92 camaro from the factory,I am trying to contact the guy that did his work to see about how it was done (balancing)
Bob
lim,
Some of the early "roller" blocks had lifter bores that were not the same size from top to bottom. They were used in truck engines that did not have roller cams. If you try to go with a hydraulic roller on these blocks you will have oil pressure problems. You have to look at the lifter bore in the block. If it is the same size all the way from top to bottom, you are ok. If there is a step at the top, making the top 1/2" or so a larger diameter hole, you can only use non-roller lifters. The roller lifters have thier oil hole higher in the body than the non-roller lifters do. When they come up on the top of the cam lobe, the oil hole is exposed in the stepped area of the bore and you lose oil pressure. I found this out the hard way on an engine I built for my own Blazer
I have only seen a few of these blocks over the years so I don't know how common they are.
Originally Posted by rmbuilder
The 1988 block is a roller set up w/ neutral balancer and external flywheel.
Bob
Bob
The boat is an 88 but that does not mean the engine was cast in 88.
