carb size and jetting >
Old 03-06-2006 | 06:20 PM
RLW
Default Re: carb size and jetting
Please read this article in regards to reading spark plugs.
It is a misconception to "read" the porcelain for jetting.
http://www.maxracesoftware.com/spark_plugs.htm
RLW is offline
Old 03-06-2006 | 06:54 PM
sounds like you need to pull that motor and dyno it-cause everything else is just a guess-do a wot plug reading-sounds to me like you should be staggering the jets anyways-oh by the way-if your boat flips or you have an accident ( which I hope you dont) and the insurance company finds out you removed the antisiphon valve or check ball-you might as well kiss your insurance good bye!!that check valve aint restricting anything-
mr mercruiser is offline
Old 03-06-2006 | 07:53 PM
Originally Posted by nordic95
You and I spoke via e-mail.Roccard built the motors.I only have dyno time,about 50 minutes of total run time.I pulled the plugs and they have just the smallest tan color on them.When I get them in the boat I will run O2 sensor to finale tune.
PS: I ment my last reply to AIRTIME,Sorry Rum Runner
OK, now that makes more sense.... Thought I was starting to loose it, or my CRS was kicking in again.
RumRunner is offline
Old 03-07-2006 | 07:31 PM
AIR TIME's Avatar
carb is going to nickerson's this week ,with the dyno sheet .this carb was a BG circle track racing carb, thats what they told my engine builder to use back in 95. when it was making 585hp. on the dyno.I will talk to them about the timing too . so they will strip it down and built it right for a boat not a car thanks for all the help guys it means a lot to me If anyone needs a help on flooring Q/A s I can help
AIR TIME is offline
Old 03-07-2006 | 07:48 PM
RLW
Nickerson's are great to work with and stand by their word.
There are others on this board who make promises they can't keep.
Dean and Brad Nickerson are the real deal. Top Shelf!
RLW is offline
Old 03-08-2006 | 09:38 PM
AIR TIME's Avatar
Thanks RLW This is going to be the missing link, now its buy a $1,300 1050 which they think will make even more power than I was getting on the dyno or rebuild my 850 bg for $550 to $600 bucks. LOOKS more like the rebuild this yr thanks again everyone. art
AIR TIME is offline
Old 03-08-2006 | 10:46 PM
HotPursuit's Avatar
We always use exhaust pyrometers to dial in exhaust temperatures.Dyno will get you close but in the real world you
will be on the throttles longer than 15 seconds.Hand held or in
the dash is some real cheap insurance. Just my 2
HotPursuit is offline
Old 03-09-2006 | 04:01 AM
RLW
Air Time,
I bought a used 1050 off the Internet for $300. I talked to Dean before I sent it to him. I explained what vintage 1050 I had and he told be it was a good candidate for a Nickerson conversion. By the time I was finished, I had $900 total, into the carb. You could try that route. Also, your current BG could be sold to offset the cost.
By the way, this is my second Nickerson carb. I had such great results with the first experience (Blower Carb), I didn't have to hesitate on sending my current carb (NA).
This carb had a little quirky leak down, hard starting anomaly going on (post Nickerson conversion). I dealt with it for two years. I sent him the carb two weeks ago, with a letter explaining what was happening.
Too make a long story short, they swapped out bowls, metering blocks (can develop internal cracks, rare), checked the circuitry and ran it on the dyno (they use O2 sensors to get the A/F ratio dialed in). I received the carb yesterday, no charge. Not even shipping.
How many people are doing that in today's world?
Russ
RLW is offline
wstultz
5
09-07-2006 06:21 PM
AIR TIME
7
06-28-2005 02:19 PM
lorne
1
09-29-2004 01:52 PM
johnnyboatman
12
03-31-2004 09:28 PM
1Boatnut
5
07-28-2002 10:41 AM
