-   -   330/454 Bravo 1 (https://www.offshoreonly.com/forums/general-q/123464-330-454-bravo-1-a.html)
GOODT 02-26-2006 02:38 PM
Re: 330/454 Bravo 1
2 Attachment(s)
unless some one added something off the wall theres no shut off unless an elect fuel pump is used
you can check and see if you have power at the coil by hooking A test light to the purp side of the coil turn switch on
here is the wiring diagram it for a 93 sorry thats as far as I go back but should be about the same
