drive type
Old 03-04-2006 | 10:14 AM
Default drive type
5.7l vortec is out for rebuild to mild 383. Am considering switching from Alpha to Bravo. If do this, any recommendations on which Bravo to use / stay away from (1, 2, 3...)? Boat is small (21', 3000 lbs). Looks like engine should be somewhere around 390Hp.
johnsc91 is offline
Old 03-04-2006 | 07:06 PM
glassdave's Avatar
Neno the mind boggler
Default Re: drive type
you should be fine if you already have an Alpha, go easy on the starts and watch the air time. Bravo 1 would be better but not necessary. what are your driving habits? welcome to the board by the way.
08 OPA High Points Champion
glassdave is offline
Old 03-04-2006 | 07:56 PM
mopower's Avatar
Toxic FORMULA
A friend of mine ran a 406 sbc @ 470 hp thru an Alpha in a 20' bowrider for three seasons and no probs. Sold boat with orig. 350 mag and it's still going.
Like Glassdave said "go easy on it" and watch the "air". Unless you have a heavy boat , I wouldn't worrry about it.
mopower is offline
Old 03-04-2006 | 08:39 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Alpha would be faster because it is more slimline. At least from what I've heard.
US1 Fountain is offline
Old 03-04-2006 | 09:21 PM
glassdave's Avatar
good point US1. also if you want to get a bit more performance try and find an Alpha SS drive.
Old 03-04-2006 | 10:34 PM
Thanks for responses.
Am just concerned about trashing the alpha. It is newer and has been gone through. From the labor standpoint, the engine & drive are currently out. Can pick up a Bravo 1 & transom for approx $3000. Figured could sell Alpha while it in good condition, etc.
Should probably just keep Alpha, drive conservatively & enjoy the boat. Seems like everything one does to a boat is $1G+.
johnsc91 is offline
Old 03-04-2006 | 11:13 PM
woody1's Avatar
I have talked to atleast 2 dozen people running healthy small blocks with alpha drives and they all concur about the same, keep the prop in the water and take it easy on holeshots and you can hammer down when on plane
I plan on doing the same with a mild 375hp small block im building right now
woody1 is offline
Old 03-05-2006 | 12:02 AM
glassdave's Avatar
VERY IMPORTANT- make sure you keep the drive oil fresh. try to use only Merc HP or Amsoil if you want to go synthetic. also get a good drive shower. i run the chit out of my Alphas and they do just fine. an im in a 6500lb boat to . only time i have ever lost one was a prop strike once and lost a seal in an upper another time.
Old 03-06-2006 | 09:18 PM
outdrive man's Avatar
if you go with the bravo remeber that you will also need a seawater pump and some shifting mods
outdrive man is offline
Westcoast
Scarab
102
08-21-2025 03:42 PM
Nicolasticity
Drives and Lower Units
4
01-23-2008 07:45 PM
Pure Energy
Prop Talk
1
09-06-2007 10:46 AM
LostinBoston
08-29-2006 06:31 PM
scottie150
5
08-30-2005 11:31 PM
