Question about GGB Mufflers
You can weld the inside dump shut and drill an external one. I wouldn't unless I wanted louder exhaust. This far back in the exhaust I wouldn't worry about reversion. I've never had an issue. You should kill 15-20 dbs with water running in the mufflers. And they will not discolor.
Charter Member #34
I installed them Saturday and ran the boat on the hose.
It was much quieter then I expected, but still sounded good. Kind of took the edge off.
I did remove the rubber flappers. I bet it is very quiet with them on.
Does your water dump inside or outside the tailpipes?
Charter Member #34
The water realy helps quite them down. We've tried running GGB's on Stellings both wet and dry and they are amazingly quite with just a little water entering and no flappers.
zt260, what was the deal on those blower motors? I heard about that problem and it got us worried becuase we put a few on 1500hp mills too. We never saw a problem and believe me, with those mills I was concerned!
The 700hp n/a motors will work just fine. We've noticed the low end picks up a bit on the bigger hp n/a motors and GGB's.
Can you elaborate on this? I have 510 c.i. 645 h.p. Sterlings. Are you suggesting I will see improvement in low-end torque with the GGB's installed?
Thanks,
Chris
