Testing of CMI sound elimination mufflers >
Old 03-30-2012 | 10:17 AM
Have any of you guys with 5" exhaust ever used these?
http://www.imcomarine.com/cal_store/...-mufflers.html
Sorry; not trying to change your topic.
SDFever is offline
Old 04-01-2012 | 02:11 AM
SFOcean's Avatar
Charter Member #394
Originally Posted by drpete3
So I have 4 of these but changing from SC engines to NA. I was told by one person I should use different mufflers on my NA motors. I really dont want to spend $2000 on new mufflers if these would be safe/fine for my new application.
As long as you have the large diameter versions and are not over 750HP or so, they should continue to work quite well for you.
SFOcean is offline
Old 04-01-2012 | 07:54 AM
Run these on my 30' scarab. They do make a huge difference at idle yet no noticeable difference at WOT. I did a little test on one engine when I was running it on the stand. With my DB meter I got 108db at an idle with no mufflers and 84db with mufflers. These numbers were taken from the same location that the videos below we're shot from. See the tests below. These are dry pipes with a little bit of water allowed into the pipe
http://www.youtube.com/watch?v=Xy-7U...e_gdata_player
http://www.youtube.com/watch?v=ZX0sV...e_gdata_player
502ss is offline
Old 10-27-2018 | 09:01 AM
Originally Posted by Too Old
Yes.....there's a rubber seal inside that will burn up without the introduction of water. CMI is currently testing a couple variations with other materials that would take the heat of dry exhaust. I look for a dry version in the not to distant future.
this is a old post.. But you say, there is a rubber seal inside? have that all Muffler from cmi?
I have two pair of the elimination muffler for the 4" clamp on, and 5" outside diameter.. i donīt see any rubber..?
Have you a picture of the seal?
thanks
nova2_excalibur is offline
Old 10-27-2018 | 08:56 PM
thanks
You will never get a response from him. He is gone from OSO and owed a lot of people a LOT of money.
Griff is offline
Old 10-28-2018 | 11:28 PM
SFOcean's Avatar
Charter Member #394
For what it's worth, mine didn't have any rubber in them.
SFOcean is offline
Kelly O
3
04-10-2007 03:57 PM
375stinger
0
06-27-2006 06:08 PM
Livorsi Marine
New Products and Member Discounts
0
06-06-2006 02:38 PM
