need bravo help! >
need bravo help!
need bravo help!
Old 03-17-2006 | 08:03 AM
copiercat's Avatar
Default need bravo help!
im changing the gears in my late 90's bravos to 1:50's and the gears i got are the X-drives which are supposed to be stronger,im wondering if any bravo guru;s know what else has to be changed to make them work,i see they use different shims and such and maybe the clutch.call me or write me 941-302-3828,
scott
copiercat is offline
Old 03-17-2006 | 12:31 PM
Default Re: need bravo help!
Call Mark @ Bam, he'll know
954-545-8681
JaayTeee is offline
Old 03-17-2006 | 01:52 PM
Mr Gadgets's Avatar
Charter Member #601
Scott,
the clutch, shift fork, tower races, shims, thrust bearings, inner thrust bearings, just about everything in the upper.. There is a kit that provides all the parts needed to switch, much better cost for all the parts..
Hope this helps
Dick
Mr Gadgets is offline
Old 03-17-2006 | 02:57 PM
GOODT's Avatar
Originally Posted by Mr Gadgets
Scott,
Hope this helps
Dick
This is correct only way to go!!!!!
GOODT is offline
Old 03-17-2006 | 04:20 PM
copiercat's Avatar
thanks guys, now i have a direction
do you think its worth it to upgrade or should i send the gears back and just stick with the stocker
Old 03-19-2006 | 08:50 AM
Mr Gadgets's Avatar
Charter Member #601
What boat, power, NA or blown, etc??
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
