thunderbolt ignition with vortec heads >
Old 03-22-2006 | 07:39 AM
Default thunderbolt ignition with vortec heads
Hi,
I'm looking for a replacement for a merc 7.4. The engine I have now is a 1997 with the gen VI block with Mark V heads. I've found a couple sources for rebuilt engines, and the cost difference between the Mark V head and vortec head is negligable. I've heard the vortec heads are better. That being the case, anyone know if I can just bolt my existing manifold/carb to the vortec heads and use the thunderbolt V ignition? Or do I need a different timing module? Any advice welcome!
Thank
tewks is offline
Old 03-22-2006 | 08:38 AM
Pat McPherson's Avatar
Default Re: thunderbolt ignition with vortec heads
The intake will bolt up, but I would suggest you buy a new large oval port intake to match the L-29 heads. The carb will work the way it is.
The Thunderbolt ignition will work fine, just keep you initial timing at 8° or less. No more than 30° total advance with the Vortec heads.
By the way, I have a 250 hour 1999, L-29 long block I would sell. She was running strong when I replaced it with a 502...
Patrick
Pat McPherson is offline
rockstar38
8
08-28-2008 06:28 AM
Gordo
4
08-23-2008 09:09 AM
5050
0
05-27-2008 09:12 AM
tontom1989mercv6
06-26-2005 10:48 AM
BAD-HABIT
5
04-15-2002 08:03 PM
