what happened, heres the details--- >
Old 03-27-2006 | 05:55 PM
Joe's Avatar
Joe
Offshore Cowboy
Default Re: what happened, heres the details---
Jason,
How many hours?
Might also have the headers pressure checked. You may have a leaky one. Also, depending on who's working on it.... don't get sold on " your heads are bad and you need new ones." I won't name him/them, but someone you have to know on the lake, tried to tell me mine were bad (2 summers ago). So, before letting them work on it, I had the heads shipped to my engine guys here in Houston (Owens Racing), and it was fixed --- majic!!!
Turned out, I had a bad alignment pin (aka... something or the other -- don't remember the tech. name for it).
In any event... I'd check the headers.
Joe is offline
Old 03-28-2006 | 08:29 AM
Mike Paula's Avatar
Originally Posted by US1 Fountain
Intake gaskets are the number one thing to check whenever someone says they have milkshake oil, in my book.
What type of intake?
YES good call! Also a very wise old Wrench (no not wench) told me when I was young and stupid, Start with the cheapest work to the most expensive part. With a little modification I used that with my students, Check the easiest and work to the hardest.
Mike Paula is offline
Old 03-28-2006 | 10:02 AM
Wobble's Avatar
SORE MEMBER
Keep on torqing it down as many rounds as needed until the 1st bolt in the sequence holds the torque.
Sounds like you got quick service. good luck
Try using Blue Hylomar around the water jackets on your intake. I have had great success with this on all water passage gaskets. It doesn't get hard and seems to be a good corrosion inhibitor.
Wobble is offline
J-Bonz
Apache
5
01-07-2006 11:01 AM
BajaRunner
05-22-2005 04:14 PM
THATS IT
Fountain
6
10-10-2004 11:03 AM
mg503
Baja
6
07-23-2004 01:58 AM
Pantera1
05-27-2004 07:36 AM
