#3 speedmaster question >
Old 03-31-2006 | 06:09 AM
nocigarette's Avatar
Default #3 speedmaster question
does any one out ther have a diagram on the speedmaster #3 i want to tear mine down and check it but i have never had one apart.........
nocigarette is offline
Old 03-31-2006 | 06:24 AM
clearcut3's Avatar
Default Re: #3 speedmaster question
Click on the particular part you want to see a diagram for and it will pull one up along with ordering info:
http://www.mercruiserparts.com/selec...doc_nbr=+13668
clearcut3 is offline
Old 03-31-2006 | 08:35 AM
TomFTM's Avatar
just beware, you will need some special tools to put it back together.
TomFTM is offline
Old 04-01-2006 | 07:21 AM
the boat i bought has been out of the water for 7 yrs due you think the seals are bad, The boat has no power yet im just trying to get everything done and checked out before the motor gets here
Old 04-01-2006 | 08:37 AM
I would have them resealed.....it is cheap insurance seven year-old seals not good. I would take a real close look at the Drive shaft bellows too. Ed
Darkspoilerzx is offline
Old 04-01-2006 | 08:40 AM
As far as taking them apartand inspecting them, the upper is alot like a trs just bigger, seal drivers are needed to replace the seals but just to inspect on the upper some o-rings and some perfect seal and torque specs will git-r-done. Ed
Old 04-01-2006 | 02:02 PM
Reed Jensen's Avatar
SSM #3 are a little more complicated than what you can see in the parts blow-up... they have two decending shafts that have seperate gears that need to mesh and several gears along the prop shaft. One rotataion has a "bull gear" which has teeth on two sides. The oppositer rotation has two gears with teeth on one side only. Plus you need some special tools to even take the nose cone off. Good luck. They are a pain in the butt if you don't have a stand to hold them while working on them. They are heavy and ungainly. If you don't have the manual... don't think about taking them apart. You just might "think" you are putting them back together correctly, only to have one of the small decending shafts shear because they weren't phased correctly and the load was all directed to one shaft.
If you are really tricky, and you can hold the outdrive in the correct position so that the lower gears don't fall out of position. The prop shaft can be removed while a "stand in " shaft is slid into it's place. This will hold the gears and shims in their correct order. Then the three seals near the prop can be replaced without having to totally disassemble the drive. I did this on mine. But... I also have a rotating stand and fixtures to hold the outdrive and a specially sized shaft to hold the gears.
Reed Jensen is offline
Old 04-01-2006 | 09:49 PM
holy crap i think ill just back the truck in and leave the boat on the trailer start and run the motor and see if anytihg leaks then go from there.................thanks though
Old 04-01-2006 | 09:51 PM
oh yeah does anyonre know where i can get just the lowers for gill exhaust.......i think there dry i have the [email protected]
Old 04-01-2006 | 10:07 PM
Nykamp's Avatar
Call Speedmaster Inc. in FL. he will take care of you, they are worth to much to work on by your self. Good luck they are great drives.
Nykamp is offline
nocigarette
4
12-26-2006 05:18 PM
Prater
6
02-28-2006 11:25 AM
vtec
3
09-22-2003 04:45 PM
