Single Speedmaster III prop height >
Old 04-06-2006 | 01:17 PM
Default Single Speedmaster III prop height
Swapping out a sick TRS for a Speedmaster III on an old Magnum Raceboat. Can anyone give me a ballpark on how far below the keel I want to locate the propshaft? While the boat is barebones and light for a Magnum it is probalby heavy compared to most modern boats. I will be running around 500 hp initially. I have seen suggestions of everything from 2.5" all the way to 6" in old forums. I have tried to contact the factory to no avail. Any help would be greatly appreciated.
41hatteras is offline
Old 04-06-2006 | 03:49 PM
CIG3's Avatar
Default Re: Single Speedmaster III prop height
I'd start high, you can always space it down. I'd say about 3" ould be a good start. You are probably gonna have to cut the rub rail area to get the gimble that high.
CIG3 is offline
Old 04-07-2006 | 08:45 AM
Better check. I dont think you can use spacers on an early SSM III.
rdoactive is offline
nocigarette
Swap Shop
2
08-04-2008 04:07 PM
Banana Split
American Offshore
5
10-28-2005 03:21 PM
GO4BROKE
3
06-15-2005 08:27 PM
mondorally
12
01-06-2005 04:26 PM
