Intercooler water supply
Originally Posted by H2oRigger
3/16 = perfect. wouldn't go much deeper. Remember intercooler seperate feed. All my intercoolers are natural fed. no water pump. Phil
How about some pictures of the fitti ng and the set-up inside the boat. I might consider doing this myself instead of tapping into my cooling system like its set-up now.
This pick-up go's straight to a sea strainer then unrestricted thru the intercooler,the only time the intercooler is getting water is when your under way. Yes some people disagree with sea strainers but for the intercooler it is a must. Also with such a small amount of the pick-up in the water your chance of picking up something big is SMALL.
Warmest Regard Phil
Warmest Regard Phil
Originally Posted by BADKACHINA
Where do you get that fitting? I looks pretty easy to install, you counter sink the bolt holes and they go into some kind of bracket on the inside?
Available everywhere.......
Drop through pick-ups are commonly used on cats.
here are a couple of photos from teague marine.
http://teaguecustommarine.com/2002/catalog/84_pg.html
Well looks like I have another project to do.......
At least this one looks pretty easy and inexpensive, except for the seperate sea strainer. I guess it's pretty important for the intercooler not to be tapped into your cooling system?
