MSD Distributor rust >
Old 04-14-2006 | 10:26 PM
H2oRigger's Avatar
Default Re: MSD Distributor rust
Yeah this needs more checking, often to see if it happens again.
Don't want to see this photo again. If you look at the top of the gurdles and the bottom of the heads you can see the milk shake. too much back firing= blown head gasket.
H2oRigger is offline
Old 04-15-2006 | 12:06 PM
I think it is inexcusable for a distributor, sold as a marine unit, to rust up the way they do.
Bought one MSD setup on first boat, rusted every year. Last MSD junk i ever bought.
I MUCH prefer the Crane HI-6M, and the stock Merc. distributor is hall effect to boot. MSD who?
HP350SC is offline
Old 04-15-2006 | 03:33 PM
KAAMA's Avatar
When I bought my boat 6 years ago, it already had the MSD billet distributors with the MSD ignition boxes. I got rid of the MSD ignition boxes and I went with the Crane Hi-M6 ignition boxes instead, but I decided to retain the MSD billet distributors. I also decieded to go with an MSD crank trigger system relying on the pickup from the crank vs inside the distributor. With a crank trigger system the timing never moves, and it is a very reliable set-up. I've had it for 6 years and no problems.
I've had the same original Crane HI-M6 ignition boxes for 6 years without any problems (fresh water environment) as well. One of the Crane boxes even had several gallons of hi-pressure water sprayed on it when I first installed it 6 years ago----still no problems after all these years.
KAAMA is offline
Old 07-22-2006 | 08:31 AM
boatman22's Avatar
I just bought 2 crane HI-6M boxes for my boat. What is the correct hookup to merc style Dist? Are they Hall Effect or magnetic? Thanks for any info
boatman22 is offline
Ran-Dom 32
Wanted
0
02-21-2008 02:51 PM
Pure Energy
15
08-20-2006 09:26 AM
Donman
13
07-12-2006 06:56 PM
Vinny P
23
03-20-2005 06:43 PM
MIKE H
9
05-11-2003 07:18 PM
