Starter problelm >
Starter problelm
Starter problelm
Old 04-21-2006 | 11:12 PM
sleek1's Avatar
Default Starter problelm
Just replaced the starter in a 97 350 merc. Turned over fine at the house; polished her up and got to the ramp.... errrr. You know the sound. Question is, could the fly wheel have a bad spot on it? Bad-new starter? Or is there something else I'm totally missing? Any help would be appreciated.
sleek1 is offline
Old 04-22-2006 | 06:25 AM
KAAMA's Avatar
Default Re: Starter problelm
sleek,
There is an old thread that was originated in 2004 by "Dyno" called "Help, I'm in starter hell!" It was just brought up here again in the tech section about a week or so ago because some people had more questions/problems. Do a search on that thread and you will find all kinds of senarios of what could be wrong.
KAAMA is offline
Old 04-22-2006 | 06:38 AM
GOODT's Avatar
Originally Posted by KAAMA
sleek,
there are all kinds of reasons for it not to start you can do as stated above or get the manual and follow the flow chart,
it could be anything from bad batt,cable connection,bendex,flywheel ect
and yes have seen bad starters right out of the box
GOODT is offline
Old 04-23-2006 | 07:16 AM
I have also seen bad starters right out of the box , not just reman'seither brand spankin new ones with missing parts or just plain didn't work. Check all of your connections. Clean and tight, I don't like using the wing nuts that come with most marine batteries, change them to a good stainless nyloc. check the ground connections at the block if ya have to take it off and remove all the paint from under them. Ed
Darkspoilerzx is offline
Old 04-24-2006 | 01:07 PM
sleek1's Avatar
Thanks guys,
I'll go over everything in a couple days. Very frustrating. Just can't figure out why the engine started in the driveway but not on the ramp. I'll take a look on Wed.
sleek1 is offline
Old 04-27-2006 | 08:55 PM
sleek1's Avatar
Found the problem, the boat must have ingested some water last season. Pulled the spark plugs and 2 starboard and one port cylinder had water drain out of them. Changed everything and it fired up. Still have to take a look at the new starter/flywheel. Still grinds once and a while, then fires on second start. May have screwed up some teeth when the moter was "locked up". Thanks for the replies.
sleek1 is offline
nordic95
6
06-06-2010 11:29 PM
dyno
36
09-07-2006 09:00 PM
dyno
7
06-26-2004 12:16 AM
blue thunder
16
01-17-2002 09:45 AM
