MSD Marine ignition problems!!!!!! MSD = total junk? >
Old 05-12-2006 | 11:33 AM
  #41
Wobble's Avatar
SORE MEMBER
Default Re: MSD Marine ignition problems!!!!!! MSD = total junk?
Originally Posted by boatman747
I just bought a new boat . Full msd system previously installed. How much advance should come from the 6-m box ?
none, relies on distributor for advance. Be sure and put di-eletric grease in all the connectors, see my post above
Wobble is offline
Old 05-12-2006 | 01:54 PM
  #42
Banana Split's Avatar
I also had a problem every year or two blowing boxes untill i put a msd rfi noise filter in the system it stopes sugers that trash the box. havent had a problem in the past four years.
Dave.
Banana Split is offline
Old 08-17-2015 | 08:25 AM
  #43
Dean Ferry's Avatar
Veteran: Air Force
Well, add me to the list, got to the ramp yesterday, and the Talon wouldn't start, no spark at the spark plug, and nothing coming our to of the coil when I'm cranking the ignition. I think it's the coil....
http://www.msdperformance.com/Produc...r_SS_Coil.aspx
This is the distributor I am running also:
http://www.msdignition.com/Products/...stributor.aspx
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 08-17-2015 | 10:00 AM
  #44
i can tell you that coil does not like marine use.i used to use that coil before i switched to daytona sensors system and i had a couple of them fail.
mike tkach is offline
Old 08-17-2015 | 10:23 AM
  #45
Dean Ferry's Avatar
Veteran: Air Force
Mike,
Is this what you now use?
http://www.ebay.ca/itm/102002-Dayton...-/271659901291
Thanks,
dean
Old 08-17-2015 | 11:06 AM
  #46
The daytona system is very nice. It is the old crane system with some additional features. Blows MSD out of the water.
wfo1 is offline
Old 08-17-2015 | 11:30 AM
  #47
Dean Ferry's Avatar
Veteran: Air Force
WFO1,
If I just need to replace my coil, can I buy the Daytona coil to run with my MSD dist. ready to run system?
Thanks,
Dean
Old 08-17-2015 | 04:36 PM
  #48
SFOcean's Avatar
Charter Member #394
Dave.
Yep, it is MSD part number 8830.
SFOcean is offline
Old 08-17-2015 | 05:14 PM
  #49
35fountain's Avatar
I have the MSD 6 blue box and MSD billet marine distributor in my boat over 6 years...never had an issue
35fountain is offline
Old 08-17-2015 | 06:01 PM
  #50
vintage chromoly's Avatar
You will. Only a matter of when and how far from the dock you are.
vintage chromoly is offline
