Borg Warner C72 Operating Pressure ? >
Old 05-28-2006 | 08:29 PM
Mbam's Avatar
Offshoreonly Advertiser
Default Re: Borg Warner C72 Operating Pressure ?
That is the reason for our 8o psi spec, under that they don't engage. I bet the pressure is over 80 psi when you first fire it up. Take the regulators apart, many times there is some crap or a burr keeping the regulator valve off the seat that will drop the pressure at idle.
Mbam is offline
Old 05-29-2006 | 06:50 AM
Scarab3DMC's Avatar
what about running pressure ?? what should it be ??does the trans have to come out to pull the regulators?.....MY MERC MECH. SAID I SHOULD HAVE CLOSE TO 190 PSI @ 3000 rpm under load..??
Scarab3DMC is offline
Old 05-29-2006 | 09:40 AM
Mbam's Avatar
Yes, should be up around 190. THe regulator comes out by removing the shift arm and then pulling the cover where the neutral switch is. I't about the only thing you can check without pulling it.
Mbam is offline
Old 05-29-2006 | 09:50 AM
Scarab3DMC's Avatar
THANKS AGAIN MARC...!!...anything else that can cause the low pressure ??
Old 05-29-2006 | 09:56 AM
Mbam's Avatar
Yes, but then you have to pull them. Pump, housing, reverse adapter, missing/cracked seal ring, worn bushings in planatary.
Mbam is offline
Old 05-30-2006 | 07:09 AM
Scarab3DMC's Avatar
are the regulators rebuildable..?? replacement cost ??...worst case senario...how much for rebuilts exchange ?? (trade in my two complete units for rebuilts..or totaly rebuild existing ?)...
Old 05-31-2006 | 07:41 AM
Scarab3DMC's Avatar
Marc...I pulled the regulators...what should I look for ??..how do you test them ??...should I send them to you ?
Old 05-31-2006 | 08:08 AM
Mbam's Avatar
We can take a look, there really is no way to test them without being in the transmission. Figure $90 each to dis-assemble, change spring, re-assemble.
Mbam is offline
Old 05-31-2006 | 08:15 AM
Panther's Avatar
Frank's Marine Service
What kind of trans fluid are you running?
I was running regular tans fluid once and didn't have much reverse after a long run. As per Mark I switched over to type F and my problems went away.
Panther is offline
Old 05-31-2006 | 08:58 AM
Scarab3DMC's Avatar
using Valvoline type FA as Marc recomended..
