oil pumps and pan capacity
Re: oil pumps and pan capacity
Sounds sweet I always loved the Pachanga.
oil capacity is 8 quart pan
As your oil question others would need to pipe in. I am sure there is a thread some where.
My oil pressure starts at 70 cold and will be 40 at idle after a wide open hair blowing ride and basically build back to 60 at idle after the oil has cooled down.
I started with the stock 330 HP and Bravo. The Bravo is probably on borrowed time as it has never been apart. Just oil changes.
I am going to try a Mirage 27P this weekend to see if we have enough power to turn it.
Currently I am spinning a labbed 24 3 blade
Originally Posted by mcrsr
also, because i am now running a hi volume pump should i switch to 10w40 castrol so the oil flows faster??? any suggestions??
Just be carefull not to overcool your oil . 220* is perfect.
Add an oil thermostat if you want to be sure, and install a oil temp sender in your oil pan.
KEPP
New Products and Member Discounts
4
03-06-2005 09:28 AM
