Exhaust Riser gasket change >
Old 05-26-2006 | 08:24 AM
  #41
fund razor's Avatar
Default Re: Exhaust Riser gasket change
Originally Posted by Wobble
I would run a straight edge across it, if it's good then bolt it up, the gasket will take care of small imperfections. If not, then break out a flat file
Thanks Mark.
maybe a dumb question... but does the paint make a difference?
(On a block I would use laquer thinner or something to get the paint off... but I suspect that it doesn't matter on a cast iron manifold.)
fund razor is offline
Old 05-26-2006 | 08:28 AM
  #42
Wobble's Avatar
SORE MEMBER
Originally Posted by fund razor
Thanks Mark.
there are no dumb questions in this forum except....
Paint will help with corrosion, and make the gaskets stick like crazy, if you were looking to disassemble any time soon, then no paint might be better. For the long run, paint helps IMO
Wobble is offline
Old 05-26-2006 | 09:32 AM
  #43
fund razor's Avatar
Paint it is.
The rest should come today and I will be re-assembling by tomorrow.
Some people say double the exhaust gaskets.
Ever heard that one?
Old 05-26-2006 | 09:58 AM
  #44
Wobble's Avatar
SORE MEMBER
Paint it is.
It's a band aid for non-flat surfaces. I highly recommend re-torquing the manifold bolts after the first heat cycle and then again after about three. You will be amazed how much they will move. (same for intake manifold)
Wobble is offline
Old 05-26-2006 | 11:35 AM
  #45
fund razor's Avatar
Hey Mark... in the meantime I got an email from Mcollinstn saying that the paint has to go.
Now I'm conflicted.
You are both smart.
Old 05-26-2006 | 11:52 AM
  #46
Wobble's Avatar
SORE MEMBER
I never had a problem with paint being there, it helps stop rust running down the side of the block. Correct torquing and re-torquing is the main issue with manifolds IMO.
Maybe someone else with chime in with their opinion, or maybe you could call the manufacturer and get the final word.
I can only go with my experience, and am always willing to learn as I have on many occasions through this forum.
I don't believe it will be an issue either way.
Wobble is offline
Old 05-26-2006 | 12:11 PM
  #47
fund razor's Avatar
Thanks for the response.
Have a good weekend.
Old 05-26-2006 | 12:47 PM
  #48
fund razor's Avatar
Just hung up the phone with Dennis Moore on his cellie.
He says to take a file to any wierd paint drips or anything... but other than that... he says bolt those beyotches on and go boating.
Old 05-26-2006 | 01:31 PM
  #49
Fund Razor,
Did he say to file the paint off or just check to make sure the surface was flat.
Island Time is offline
Old 05-26-2006 | 02:06 PM
  #50
Wobble's Avatar
SORE MEMBER
Originally Posted by Island Time
Fund Razor,
Flat, I believe.
Wobble is offline
