Is It True
Old 05-15-2006 | 07:14 AM
offshoredrillin's Avatar
Default Re: Is It True
Originally Posted by BY U BOY
THE MOTOR IS STOCK UNTILL NEXT WED. IDECIDED TO GO WIHT 502 ALUMINUM HEADS, MARINE POWER ALUMINUM MANIFOLDS SND RISERS, 750 HOLLEY, MSD, AND A NEW CAM. I THINK THIS SHOULD PUT ME AROUND 450-475HP. WITH THESE UPGRADES SHOULD I USE SYNTHETIC AND WHAT WOULD BE THE BEST SEALS TO USE.
If you're doing all of this to the motor, then the only gasket left for you to change would be the oil pan gasket and rear seal. If you have the motor out thats an easy enough fix.
offshoredrillin is offline
Old 05-15-2006 | 09:34 AM
BY U BOY's Avatar
Im Not Pulling The Motor So Thats A No Go On The Main Seal And Oil Pan. I Have Decided That It Is Not Worth Using The Synthetic I'll Stick With The 40w.
BY U BOY is offline
Old 05-15-2006 | 10:21 AM
Panther's Avatar
Frank's Marine Service
You said you were changing the cam? What kind of timing plate cover do you have?
If it's a one piece timing cover you'll need to to drop the oil pan. It is best if you pulled the motor for that. With that being said, change the main seal while you're at it.
Panther is offline
