Oil temp question >
Oil temp question
Oil temp question
Old 05-14-2006 | 11:10 PM
batty's Avatar
Default Oil temp question
I just put the boat in the water this weekend after installing oil temp guages over the winter. Im not sure where my oil temps should be I run castrol straight 40 in the motors 454 n/'a no major mods with no oil coolers. my oil temps after the 1st run at normal cruising speed were at about 230* and at holding at wot for about 10 seconds it would jump to 260 * and stay there, water temps are at 140* where should my temps be ? am I ok or are these too high??
thanks Brad.
batty is offline
Old 05-15-2006 | 06:34 AM
MOP
Lightbulb Re: Oil temp question
thanks Brad.
I would be looking to be in the 200 range at cruise and about 250 a WOT, surprised yours does not come back down after a good run. Check Hydro Cruisers post on Marine Lubrication very good info there.
Phil
MOP is offline
Old 05-15-2006 | 09:16 AM
fbh-velocity's Avatar
Default Re: Oil temp question
I would say you need a oil cooler. Temp are in high end but syntetic oil will survive much more heat than mineral oil
fbh-velocity is offline
Old 05-15-2006 | 01:22 PM
Dennis Moore states that full warm and running, oil temps from 230 to 270 F. is the desired range. Anything over 212 F. will get rid of the unwanted condensation and combustion water products. And full synthetic oils will handle up to 300 F. without loosing the necessary lub. qualities. But, if you plan to do much hard running, I agree that it be would well worth your while to add that oil cooler. Matter of fact; I have a 454 Mag. combo cooler that I updated to larger when I went to the built 540. You could have it real cheap. (Maybe $50 + shipping?) --- Jer
jpclear is offline
Old 05-16-2006 | 11:37 AM
I went through the same deal last year with oil temps. I spent the money and bought a hardin combo cooler. My temps didnt change much at all running but would cool down much faster with the bigger cooler. I switched to Mobil v-twin and my temp stays around 250-270 running hard. There is a bypass valve that has to be changed to make a big difference. Articfriends has a long thread about this.
REBEL4845 is offline
Old 05-21-2006 | 07:55 PM
batty's Avatar
was wondering if you still had the oil cooler if so I am intrested let me know I need two but if you have one it will get me started
thanks
Brad 419 467 6577
batty is offline
Old 05-24-2006 | 07:06 AM
Brad, your temps are fine. Ken
minxguy is offline
Velocity Vector
0
04-03-2008 01:45 PM
FormulaM2Formula
08-26-2006 03:49 PM
FormulaM2Formula
0
08-05-2006 01:36 AM
Formula311-SR1
10
06-22-2005 04:46 AM
HighPriority
2
09-02-2003 07:33 PM
