How Accurate Is a  Stock SpeedO >
Old 05-21-2006 | 09:04 PM
onesickpantera's Avatar
Default Re: How Accurate Is a Stock SpeedO
They all seem to be off. Some more than others. My Donzi actually read low(we can't have that!) and I traced it to a crappy pickup. Replaced the cheap plastic pickup with a stainless unit and it then read about 4 mph high at WFO!
onesickpantera is offline
i have most of that but dont know the raito on trs drives and what is a good number for slip % ?
myscarab30 is offline
Old 05-21-2006 | 09:23 PM
Biggus's Avatar
TRS ratio is 1.5:1, Just for a rough guess, I'd say with a TRS drive, you will have around 15% slip. (possibly higher) I've seen older TRS boats with the clamshell style water pickups mounted directly infront of the props. Audio's old 302 Formula (twin 330's) was spinning 27p props at 5000 rpm. His slip # was close to 30% !!!!
Biggus is offline
Old 05-22-2006 | 11:14 AM
my stock Norskog speedo with a stainless steel pick up is almost dead on to my handheld GPS........if anything the speedo reads a little slower.
pullmytrigger is offline
Old 05-22-2006 | 11:25 AM
Wobble's Avatar
SORE MEMBER
WFO my speedo reads 80, my gps shows the real speed (74 with a full load). in a small window that my passengers cant see.
On a poker run last year my passengers were telling everyone that we were running 80
Wobble is offline
Old 05-22-2006 | 12:28 PM
Whiteknuckle's Avatar
My speedo is a VDO that is surprisingly accurate with the GPS. However it is the exception and not the rule.
Whiteknuckle is offline
Old 05-22-2006 | 12:34 PM
BajaRunner's Avatar
Ive got a gaffrig speedo in my baja that reads almost dead nuts on to the gps. I wish it read higher than it does
BajaRunner is offline
Old 05-22-2006 | 12:49 PM
BY U BOY's Avatar
Originally Posted by 99fever27
I find my speedo is very accurate..within 1mph of my gps.
MINE IS ALSO
BY U BOY is offline
Old 05-22-2006 | 11:20 PM
markt111's Avatar
my nordskog dead on ba**s accurate unfortunately, need to change the whole set of gauges thou, so the next one may say I run 75!!!
markt111 is offline
Old 05-23-2006 | 05:52 AM
Dave M's Avatar
Veteran: Navy
My Gaffrig speedo read high, right on, or low depending on the condition of the pickup tube. When I put a brand new one on it would read +5. After a while the pickup would end up getting bent and if it was at the right angle it would be right on or close. Then it would get bent more and read low.
I got tired of buying new pickup tubes. Got a GPS speedo, DONE!
Dave M is offline
Dock Holiday
14
08-03-2006 04:44 PM
HOTTZU98
13
05-06-2005 08:35 AM
berns29scarab
4
08-25-2004 03:58 PM
Kokopelli
5
12-17-2003 04:38 AM
