496ho belt question??? >
Old 06-08-2006 | 07:17 PM
Jim Diesel's Avatar
"Unregistered Gun"
Default 496ho belt question???
I'm getting small rubber pieces on the fiberglass in front of the engine, well I saw that my belt was a little loose. So I changed my belt checked all pulley's making sure they spun freely, I put the belt back on and tightened up. First time out opened hatch after a run, small dusting like before??? What could be-causing this, belts good and tight do I need to tighten some more? Were the belt crosses the water pump could the belts slap each other since there's a small clearance there?
03 Baja Outlaw 25' 496ho
Jim Diesel is offline
Old 06-09-2006 | 08:14 AM
Default Re: 496ho belt question???
I assumed that was just normal, a little belt dust around the front of the engine. Last year when I installed my whipple I noticed it and cleaned it all up. Checked the original belt thourougly and reinstalled it. Still a little black dust but not as much as when it was new. I figured this was due to a new belt setting into the pulleys.
ComfortablyNumb is offline
Old 06-09-2006 | 10:55 AM
Reckless32's Avatar
Rough Seas Lie Ahead
Yup same here. After a long weekend I always get the dusting on both sides.
Reckless32 is offline
Old 06-09-2006 | 11:18 AM
JS232's Avatar
Normal, just clean the mess
JS232 is offline
Old 06-10-2006 | 06:09 AM
Jim Diesel's Avatar
"Unregistered Gun"
Thanks guys, I was just wanting to make sure nothing was going wrong.
bob_t
3
09-29-2008 10:41 PM
hp500efi
3
06-14-2006 10:19 AM
David Haag
7
05-04-2004 08:36 PM
26sonic
2
04-25-2003 07:12 AM
