Header Bolt torque >
Header Bolt torque
Header Bolt torque
Old 06-14-2006 | 11:44 PM
Strip Poker 388's Avatar
Rob
Default Re: Header Bolt torque
The header and intake are 3/8 which most say 35 TQ. Just back off then retouqe.Just remember that the hardware store bolt might be a lower grade even being a garde 5 compared to a name brand bolt.On the chart See the 170-180-psi bolt will be a lot stronger bolt than the hardware bolt.
http://www.arp-bolts.com/Catalog/Catalog.html
If a bolt has the correct strech it will not need a lock washer
http://www.arp-bolts.com/Tech/Tech.html
Strip Poker 388 is offline
Old 06-15-2006 | 08:46 AM
Dean Gellner Engineering recommends using a stud with a nut.. that way you have two forces of keeping the header tight.
customryder is offline
Old 06-15-2006 | 10:05 AM
Panther's Avatar
Frank's Marine Service
Have used stainless bolts on aluminum manifolds and headers for years, never any problems.
I saw a lot of problems with rust on boats that had steel bolts. Most of the time the heads would rust out and you had to hammer a smaller socket on it or a 12 pt. metric socket if you were lucky. In one instance I had to use a sledge hammer to break the manifold so we could get it out.
Panther is offline
Old 06-16-2006 | 01:20 AM
Big Block Billy's Avatar
Post Re: Header Bolt torque
Another huge load of B.S.
Use the ARP Stainless Bolts for headers. When you really get used to fasteners you get a feel for them and thier particular application ,(it's not a head gasket ) and understand their limits as well, if not then you haven't done enough motors.
Have had good luck with the 5/16 headed ARP 3/8 - 16 header bolts. After running and warming up, a good re- tightening is all they need.
You need a 3/8 " Drive ,deep socket that is necked down for for them and a normal 3/8 ratchet tightened to max with one hand.
With the CMI headers I have used these as described and have had no problems in 2 years with 4 motors.
Another thing is to coat the gaskets with anti-sieze compound before install. Believe it or not they really do work well. Try it on a carb gasket too.
Make 'em tight and even , it's childs play... BBB
Big Block Billy is offline
Old 06-18-2006 | 11:29 PM
Thats what I used on My CMI's, the ARP SS Studs. I checked them a few times after the intial install and none loosened up at all. Haven't touched them in a 100hrs.
Griff is offline
Old 06-19-2006 | 08:47 AM
Cool Re: Header Bolt torque
http://store.summitracing.com/partde...5&autoview=sku
Check these out they are available from Jegs too.
Old 06-19-2006 | 10:54 PM
Panic Button's Avatar
Emerald Coast of Florida
Gil torque 35 ft#'s
Panic Button is offline
boatguy94
2
07-23-2008 08:57 PM
revomaniac
11
08-27-2006 12:02 AM
BadDog
1
03-03-2006 11:23 PM
cooltoys61
0
07-01-2004 11:54 AM
Punk Rocket
21
08-07-2002 08:33 AM
