How do you bond lexan? >
Old 06-14-2006 | 10:36 PM
R Addiction's Avatar
AT Cult Member #3
Default How do you bond lexan?
I'm making a storage compartment out of lexan. I have the three peices and need to find out the best way to "Glue' them together. I have tried a 2 part epoxy and that failed. Any ideas?
R Addiction is offline
Old 06-15-2006 | 04:33 AM
RLW
Default Re: How do you bond lexan?
http://www.eng-tips.com/viewthread.cfm?qid=50945&page=1
RLW is offline
Old 06-15-2006 | 05:13 AM
Yup, just a bought a tube Monday...
BadDog is offline
Old 06-15-2006 | 05:38 PM
AT Cult Member #3
Where can I get Weld-On 45? Home Depot? Thanks Guys!!
Old 06-15-2006 | 07:30 PM
Ted G's Avatar
Lexan is designed to be solvent welded, you really don't use a glue, you run the solvent along the seam and it "melts" together. Typically the weld is stronger than the material if done right. Any place that sells plastics will have the solvent-I'm not sure about the Depot.
www.cbpba.com
Ted G is offline
Old 06-15-2006 | 07:41 PM
Pwrbt33's Avatar
Theres a Plastics place in Annapolis that has all that kinda stuff, or they can do it. I cant remember the name ..... It'll come to me after I go to bed!
John S.
Pwrbt33 is offline
Old 06-15-2006 | 08:24 PM
Weld-on is good stuff. People that build aquariums swear by that stuff.
When I was building a sump tank for my aquarium, I went to a plastic store and they sold me some acrylic cement. It's applied with a needle applicator and uses the "capillary" method to bond the pieces together.
Your best source for the cement would be either online or a local plastics place.
synack is offline
Old 06-15-2006 | 08:40 PM
Prater's Avatar
www.usplastics.com
Prater is offline
txwatergypsy
Detailing, Painting, & Fiberglass
7
04-01-2011 12:31 PM
Crazyhorse
Northern Illinois Offshore Club
0
12-28-2006 07:38 PM
Tricky919
3
09-26-2005 07:23 AM
jryan26
Fountain
9
01-08-2004 10:51 PM
GregP
3
04-17-2003 02:07 PM
