What is the correct water pressure >
Old 06-17-2006 | 05:33 AM
vandeano's Avatar
Default What is the correct water pressure
I have the water crossover set up. What is the correct (safe) water pressure at WOT. And what about idling pressure. I have the adjustable water relief valve. Right now at idle it is at about 7 psi. When the thermostat opens it drops to about 4 lbs. At WOT it is about 20 psi. Is this OK or should I adjust for more or less psi at WOT
vandeano is offline
Old 06-17-2006 | 06:19 AM
GOODT's Avatar
Default Re: What is the correct water pressure
those numbers sound on the money !!!!!!!
GOODT is offline
Old 06-17-2006 | 09:49 AM
vandeano's Avatar
Thanks GOODT, coming from u I feel better
vandeano is offline
Old 06-20-2006 | 09:18 AM
Bad Girl's Avatar
just curious, what relief are you using? can you give me a part number?? thank you,
ken
47 Lightning SE
Bad Girl is offline
VIPER7
1
07-29-2005 08:16 AM
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
ryoung99
0
05-14-2003 06:56 PM
CayFomula
04-23-2002 09:32 PM
